Remove 2 characters from a string user parameter with ilogic inventor
jgomis.ext
jgomis.ext
Hi everybody,
I think it's a simple problem, I would like to remove two characters in a string with ilogic.
I have this parameters :
And I would like to supress the ":1" in all theses parameters. If someone have the solution 🙂
bradeneuropeArthur
Could you share the ipt file
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
jgomis.ext
Hi, I can't because it's too big.
But i'am in an .iam and I find the names of my ipt with
Form_name_viro = oAsmCompDef.Occurrences.Item(1).Name 'Virole
And the result of these names are the parameters updisdes 🙂
WCrihfield
Here is an example of a simple way to 'split' assembly component names into two parts, to get just the part before the colon (:) symbol.  When you use the 'Split' tool on a string, then specify what character to use as the splitting tool, it will return an array of Strings representing that original String split into multiple parts, determined by the splitting tool you specified.  Then I am just using (0) after that, to get the first item within that array of Strings, because array's are zero based, which means the first item index is zero, not one.
Dim sCompName As String = "Part1:1"
Dim sBeforeColon As String = sCompName.Split(":")(0)
Dim sAfterColon As String = sCompName.Split(":")(1)
MsgBox("sBeforeColon = " & sBeforeColon & vbCrLf & _
"sAfterColon = " & sAfterColon, vbInformation, "Split Component Name")
Wesley Crihfield
(Not an Autodesk Employee)
Curtis_Waguespack
Hi @jgomis.ext
You could use the Trim function for this.
I hope this helps.
Curtis
Dim TestString As String = "Long_Part_Name_Example:1"
TestString = TestString.Trim(CChar(":")).Remove(TestString.Length - 2)
MsgBox(TestString,,"iLogic")
