reference a document from Partlist in IDW
^_^clovis^_^
^_^clovis^_^
I'm trying to retrieve a document (part/assy) to get its info, from the Partlist in an IDW. But I get this error.
Sometimes it works (with some assy) but never with a single part
Sub IndexPartslist()
    Dim oDoc As DrawingDocument
    Set oDoc = ThisApplication.ActiveDocument
    Dim oSheet As Sheet
    Set oSheet = oDoc.ActiveSheet
    Dim oPL As PartsList
    Set oPL = oSheet.PartsLists.Item(1)
    Dim drawBomRow As DrawingBOMRow
    Dim oBomDoc As Document
    Dim oPLRow As PartsListRow
    Dim i As Integer: i = 1
    For Each oPLRow In oPL.PartsListRows
        Debug.Print oPLRow.Item("ITEM").Value
        Set drawBomRow = oPLRow.ReferencedRows.Item(1)
        Set oBomDoc = drawBomRow.BOMRow.ComponentDefinitions.Item(1).Document 'ERROR line
    Next
End Sub
Any help would be greatly appreciated
Sorry, wrong account
frederic.vandenplas
Sorry, previously posted on my other account!
You better check the referenceddocumenttype before traversing the partslist (assembly or part)
Dim oSheet As Sheet
If oPL.ReferencedDocumentDescriptor.ReferencedDocumentType = kAssemblyDocumentObject Then
Next
    ElseIf oPL.ReferencedDocumentDescriptor.ReferencedDocumentType = kPartDocumentObject Then
Set oBomDoc = oPLRow.Item(1).Parent.ReferencedDocumentDescriptor.ReferencedDocument
Next
End If
End Sub
If you think this answer fullfilled your needs, improved your knowledge or leads to a solution,
please feel free to "kudos"
^_^clovis^_^
Thank you very much!
I'll try your big help after the usual work activity.
Also I'll have to check this
 function.
I never saw it before.
Thanks again!
^_^clovis^_^
Hello Frederic,
That's it
Thanks for your help!
