If the base view is an isometric view in idw Titleblock scale value should b NTS
k14348
Message 1 of 9
k14348
-karthik
Replies (8)
Message 2 of 9
Sorry, wrong account 🙂
Message 3 of 9
frederic.vandenplas
Sorry, previously posted on my other account!
This does a check for the first drawingview placed on a sheet (base view)
Because i don't know how you fill the titleblock, i can't help you with that.
If needed provide more info please
Sub DrawingViewOrientation()
    Dim oDoc As DrawingDocument
    Set oDoc = ThisApplication.ActiveDocument
    Dim oSheet As Sheet
    Set oSheet = oDoc.ActiveSheet
    Dim oDrawView As DrawingView
    Set oDrawView = oSheet.DrawingViews(1)
    If oDrawView.Camera.ViewOrientationType = kArbitraryViewOrientation Then
    MsgBox "view is iso"
    Else
    MsgBox "view is bottom/top/..."
End Sub
If you think this answer fullfilled your needs, improved your knowledge or leads to a solution,
please feel free to "kudos"
Message 4 of 9
k14348
   Title block scale value comes under Prompted entry field edit. Plz refer attachment.
-karthikeyan M
Message 5 of 9
frederic.vandenplas
Then this is the code that you need...
Sub DrawingViewOrientationInTitleBlock()
    Dim oSheet As Sheet
        strscale = "NTSA"
    Else
        strscale = oDrawView.ScaleString
    Dim oTitleBlock As TitleBlock
    Set oTitleBlock = oSheet.TitleBlock
    Dim oTextbox As TextBox
    For Each oTextbox In oTitleBlock.Definition.Sketch.TextBoxes
        If oTextbox.Text = "Scale" Then 'This is the name you see in the promted text dialog box
            Call oTitleBlock.SetPromptResultText(oTextbox, strscale)
            Exit For
    Next oTextbox
End Sub
Message 6 of 9
k14348
  This code is not working. If i run this code Scale value is coming as per Base scale view. Not NTS. If the base view is an isometric view then scale value should be NTS.
-karthikeyanM
Message 7 of 9
frederic.vandenplas
Indeed, i must have overlooked something, it looks now at the upvector, when 1 out of 3 vectors is 1, it means that you are looking perpendicular to the part/assy
    Dim oSheet As Sheet
    If oDrawView.Camera.UpVector.X = 1 Or oDrawView.Camera.UpVector.Y = 1 Or oDrawView.Camera.UpVector.Z = 1 Then
    Else
        strscale = "NTS"
            Exit For
    Next oTextbox
End Sub
Message 8 of 9
k14348
   Great it works thanks for your effort.
-karthikeyan M
Message 9 of 9
Just wondering if this could be tweeked to override the view label to show NTS for all ISO views? Thanks
