- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have a configurable assembly which has a number of sub-assemblies within it, some of which are also configured from iLogic rules within the top level assembly and are rectangular patterned.
The problem I have is that the original sub-assembly is set to "iLogic" LOD and is configured correctly, but then when it is patterned, the subsequent element assemblies are still in "Master" LOD and so don't reflect the correct configuration.
Is there an easy way to force all the elements of the pattern to match the LOD of the original sub-assembly or do I have to code this in to force each one manually into the "iLogic" LOD somehow? If so, what's the best way of going about this?
