Enable print option from C++ api
prakash.muthu
prakash.muthu
I would like enable print option in certain scenarios where print is grayed out. Kindly help to achieve this using c++ api.
JamieVJohnson2
DrawingPrintManager allows you to print objects.  However, "where print is greyed out" is the reason nobody is answering this post (if not the C++ code).  Inventor has the option greyed out when it is inappropriate to print because it is busy in a sub system that is calculating something, so that's not going to be possible.  Otherwise we may not be understanding the question.
Jamie Johnson : Owner / Sisu Lissom, LLC https://sisulissom.com/
