Read WorkPoint types (separate Wire Pins from the rest)
Maxim-CADman77
Advisor Advisor
Maxim-CADman77
I need to determine which of the WorkingPoints in the given IPT are Wire Pins.
Till now I managed to print the list of WorkingPoints  (it even more entries than I can see in a browser, including the one wih an empty name placed the last)
Yet I can't determine a WP property defining points as Wire Pins (special object to be used while working inside of Cable&Harness Environment).
Could somebody direct me, please.
Thank in advance
Please vote for Inventor-Idea Text Search within Option Names
Maxim-CADman77
In empty (new) IPT there are already two WorkPoints
Origin and that noname (probably EoP-marker). I'm using this ILodic-code:
Dim doc As PartDocument = ThisDoc.Document
'[ List of Work Points
Dim ResMsgPnt As String
Dim Pnt_Count As Integer=doc.ComponentDefinition.WorkPoints.Count
Dim oPoint As WorkPoint
For Each  oPoint In doc.ComponentDefinition.WorkPoints
'Trace.WriteLine("iLogic: PointName - " & oPoint.Name)
ResMsgPnt=ResMsgPnt & oPoint.Name & "-" & oPoint.Type & vbCrLf
Next
MsgBox (ResMsgPnt,,"PointList (" & Pnt_Count &"):")
 I still need some help...
Maxim-CADman77
I've checked BIMConnectors but there is no entries here while model contains Couple of Pins. Any Ideas?
chandra.shekar.g
Autodesk Support
Autodesk Support
@Maxim-CADman77,
Unfortunately, Inventor API does not exposed API to identify wire pins. Please log this wish list at idea station using below link.
https://forums.autodesk.com/t5/inventor-ideas/idb-p/v1232/tab/most-recent
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
Maxim-CADman77
I believe i've found a faster (? indirect ?) solution.
iLogic code:
Dim oPartDoc As PartDocument=ThisDoc.Document
Dim oCompDef As ComponentDefinition=oPartDoc.ComponentDefinition
Dim oWP As WorkPoint
Dim oAttr As Attribute
Dim WpMsgBody As String
Dim WpIndx As Integer
' Check if 1st Attribute's Value in 1st AttributeSet is "ConnectorPin"
For WpIndex=2 To (oCompDef.WorkPoints.Count)-1
oWP=oCompDef.WorkPoints.Item(WpIndex)
Trace.WriteLine ("iLogicEcho" & oWP.Name)
Try
	oAttr=oWP.AttributeSets.Item(1).Item(1)
	If oAttr.Value="ConnectorPin" Then WpMsgBody=WpMsgBody & oWP.Name & vbCrLf
Catch
End Try
Next
MsgBox (WpMsgBody,,"Wire Pins are:")
Improvements are welcome.
