ContentFamily GetCustomData
sn
sn
Actually I write a Function for Custom Content Family Editor and I serialized Data as a Byte Array which i like to store with a ContentFamily Object. In the API Description of Inventor there are to Methods:
ContentFamily.GetCustomData( ClientId As String, InternalName As String, CustomData() As Byte )
ContentFamily.HasCustomData( ClientId As String, InternalName As String ) As Boolean
which would perfect fit into my needs.
The Problem is, i am not able to find the method to Set these CustomData with the API. Got this Function lost when the API was published or do i need to set the CustomData somewhere else in the API or it's just Top Secret?
Thanks in Advance
chandra.shekar.g
Autodesk Support
Autodesk Support
@sn,
Unfortunately, Inventor API does not support to add family. Serialized data info should be published to database when create family.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
sn
Could you explain how and where I can provide the customdata in the family
creation process?
Thanks in advance
chandra.shekar.g
Autodesk Support
Autodesk Support
@sn,
Adding or creating family to content center with serialized data is completely internal. This is not public yet.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
