Read the real value of overriden (static) PartsListCell
Maxim-CADman77
Advisor Advisor
Maxim-CADman77
I need to know the best (fastest) method to get the real (set in IAM's BOM) value of PartsListCell that are overriden (with value of <Static> property = True).
Of course I can start the transaction; set Static property of the cell to False; Read Cell.Value and finally abort the transaction ... but I believe there should be some easier way, right?
Thanks in advance.
Please vote for Inventor-Idea Text Search within Option Names
bradeneuropeArthur
I have some code for that, unfortunately I am far from my desk. As soon as I am back I will post it here, ok?
Autodesk Software: Inventor Professional 2018 | Vault Professional 2018 | Autocad Mechanical 2018
Programming Skills: Vba | Vb.net (Add ins Vault / Inventor, Applications) | I-logic
Dimension Component! | Partlist Export! | Derive I-properties! | Vault Prompts Via API! | Vault Handbook/Manual!
Drawing Toggle Sheets! | Vault Defer Update!
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
bradeneuropeArthur
Maybe this will help you already a bit further with it.
https://forums.autodesk.com/t5/inventor-customization/bom-row-static-quantity-programatically/m-p/82...
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Curtis_Waguespack
Hi @Maxim-CADman77
Here is a quick Ilogic example.
I hope this helps.
Curtis
Dim oDrawDoc As DrawingDocument
oDrawDoc = ThisApplication.ActiveDocument
Dim oSheet As Sheet
oSheet = oDrawDoc.ActiveSheet
Dim oPartsList As Partslist
oPartsList = oSheet.PartsLists(1)
Dim oRow As PartsListRow
Dim oColumn As PartsListColumn
For Each oRow In oPartsList.PartsListRows
	For Each oColumn In oPartsList.PartsListColumns
		If oRow.Item(oColumn).Static = True Then
			oOverride = oRow.Item(oColumn).Value 'get static value
			oRow.Item(oColumn).Static = False 'set to not static
			oValue = oRow.Item(oColumn).Value 'get real value
			MessageBox.Show("Real value is: " & vbLf & oValue, "iLogic")
			oRow.Item(oColumn).Static = True 'set back to static
			oRow.Item(oColumn).Value = oOverride 'set back to static value
    Next oColumn
Next oRow
Maxim-CADman77
Thank you but I need only read the value (without modifing the document).
marcin_otręba
You can go trough DrawingBOM to row reference document and then read corresponding value from document definition...
Hi, maybe you want to check my apps:
DrawingTools   View&ColoringTools   MRUFolders
DRoam
@Maxim-CADman77, if you're still looking for a solution for this, here's an implementation of @marcin_otręba's suggestion, plugged into Curtis's code:
Dim oSheet As Sheet
			Dim oDoc As Inventor.Document = oRow.ReferencedRows(1).BOMRow.ComponentDefinitions(1).Document
			Dim oValue As Object
			If oColumn.PropertyType = PropertyTypeEnum.kFileProperty Then
				Dim oPropSetId As String
				Dim oPropId As String
				oColumn.GetFilePropertyId(oPropSetId, oPropId)
				oValue = oDoc.PropertySets(oPropSetId).ItemByPropId(oPropId).Value
			Else If oColumn.PropertyType = PropertyTypeEnum.kCustomProperty Then
				Dim oPropName As String = oColumn.CustomPropertyName
				oValue = oDoc.PropertySets("Inventor User Defined Properties").Item(oPropName).Value
    Next oColumn
Next oRow
Not super straightforward, but it's probably the fastest way. There doesn't seem to be a way to directly get the non-static value of the Parts List cell itself. Instead, you have to query the iProperty that's referenced by the cell.
To do this, you first have to get the document associated with the cell's row, and then the property associated with the cell's column (which is handled differently depending on if it's a built-in or custom property). Then you can finally query the property's true value.
Hope this works for you.
