Read exported BOM xml file to understand column order
J_Dumont
J_Dumont
I am writing a program to export the BOM from an assembly. As I found out the BOM export from an API sorts the columns alphabetically. I would like to sort the columns based on an XML file that is used. I looked at some posts to resort the BOM xlsx file using the Excel reference. However, an array has to be created for the columns to sort by and the posts I viewed manually created the array.
I would like to read the XML file to capture an array dynamically as users typically have different needs. I am able to read the XML file but I'm trying to figure out how to determine the column order in the xml file.
I thought the XML file listed the columns in order and I created a list of column names where visible = true but it doesn't seem to be working as I first thought.
Any info on understanding the XML file would be greatly appreciated.
WCrihfield
Just checking...Is your end goal the XML file, or do you want to eventually end up with an Excel file?
Are you using a separate XML file as a reference, besides the one you're exporting from the BOM?
Wesley Crihfield
(Not an Autodesk Employee)
J_Dumont
I am exporting my BOM to a spreadsheet vis VB.Net and the columns are alphabetical instead of in the order that I configured. I used the Export function from the BOM so I can quickly change existing files to have the columns I need.
From other posts, it appears that I need to use Excel to sort the columns properly but each post I revied had the columns hardcoded. I have many users with different needs so I have been trying to read the XML file to figure out what columns the user wants and in what order and then I can create the array dynamically.
I think I figured out the XML file. It appears to export the Model Data as <Layout Index="0">, the Structured as, <Layout Index="1"> and the Parts Only as, <Layout Index="2">.
I can then capture the text from each Caption whose Visible = True and the VisibleIndex gives me the order.
<property iskey="true" isnull="true" name="Item1">
<property name="ImageIndex">-1</property>
<property name="ImageAlignment">Near</property>
<property name="Caption">Item</property>
<property name="ToolTip"/>
<property name="CustomizationCaption"/>
<property name="FieldName">Item Order</property>
<property name="FieldNameSort"/>
<property name="Name">treeListItem Order</property>
<property name="AllowIncrementalSearch">true</property>
<property name="Fixed">None</property>
<property name="ColumnEditName"/>
<property name="ShowButtonMode">Default</property>
<property name="VisibleIndex">0</property>
<property name="Visible">true</property>
<property name="SortOrder">None</property>
<property name="SortIndex">-1</property>
<property name="SortMode">Custom</property>
<property name="FilterMode">Value</property>
Please let me know if you think I missed anything.
WCrihfield
When I export the 'Structured' BOMView using this:
Dim oADoc As AssemblyDocument = ThisAssembly.Document
Dim oADef As AssemblyComponentDefinition = oADoc.ComponentDefinition
Dim oBOM As BOM = oADef.BOM
oBOM.StructuredViewEnabled = True
oBOM.StructuredViewFirstLevelOnly = True
Dim oStView As BOMView = oBOM.BOMViews.Item("Structured")
Dim oFileName As String = "C:\Temp\BOM Export to Excel test.xlsx"
Dim oSheetName As String = "BOM"
oStView.Export(oFileName,FileFormatEnum.kMicrosoftExcelFormat,oSheetName)
All the columns are the same as they were when I was looking at it within Inventor's BOM dialog.
Even all the thumbnails are in place, and scale with the cell size.
I'm using Inventor Pro 2021.1, Win10 Enterprise, & MS Office 2019.
Here's a screen shot of my Inventor dialog & my Excel sheet.
Wesley Crihfield
J_Dumont
That's great info. Unfortunately, I'm programming using Inventor 2017 as we cannot upgrade for a few months.
I will try my code on a system with the newest release and check the results.
Also, I like how you added the sheet name.
