Need a button. How is it correct?
robertast
robertast
A question for experts.
What is the right thing to do if you need a button to run the code.Convert iLogic into VBA? Or write a code in VBA that launches iLogik?
robertast
@Anonymous
Вы меня не поняли. Я знаю, как назначить кнопку макросу. И как запускается iLogik через триггер. Но если есть несколько правил и один триггер :). Кнопка в таком случае - это именно макрос. А как насчет правила? переписать или ...?
If there are several rules, use an iLogic form. Click button -> launch form -> choose from rules
robertast
If you make a form only for buttons, there is no point in them and the rule can be followed. The button is convenient to use for quick start-up and frequent use
robertast
Summary if you need a toolbar button - Convert iLogic to Macro. If there is not enough knowledge for this, we use a macro to launch iLogic:
Public Sub Buton()
Dim addIn As ApplicationAddIn
Dim addIns As ApplicationAddIns
Set addIns = ThisApplication.ApplicationAddIns
For Each addIn In addIns
If InStr(addIn.DisplayName, "iLogic") > 0 Then
addIn.Activate
Dim iLogicAuto As Object
Set iLogicAuto = addIn.Automation
Exit For
Next
Debug.Print addIn.DisplayName
Dim RuleName As String
INTERNALrule = "Rule Name"
Dim oDoc As Document
Set oDoc = ThisApplication.ActiveDocument
If oDoc Is Nothing Then
MsgBox "Missing Inventor Document"
Exit Sub
iLogicAuto.RunRule oDoc, INTERNALrule 'for internal rule
End Sub
But this is a last resort.
