Create parameters that exists
henrikubbe4438
henrikubbe4438
Hi all.
I have been looking for some time to get iLogic to create me some parameters, but only if the don't exists already. I had a version working with try-catch, but it fel ... wrong to use that method. All the searches i made came close, but didn't give me any cigarrs. I came up with this, maybe someone has a similar problem and can put it to some use.
I'm no programmer so any bad methods is mea culpa. It works through all my test trials, though and I'm happy with it so far. Any addition input is of course welcome.
Come to think of it - maybe should add a test for proper file type...
'Creates parameters from a list
'It works with most ordinary units
'set up variables
Dim myArray As New ArrayList
oMyParam = ThisDoc.Document.ComponentDefinition.Parameters
Parameter.Quiet = True
'Parameters list, change the habitants, but keep the system.
myArray.Add("p1")
myArray.Add("10")
myArray.Add("mm")
myArray.Add("p2")
myArray.Add("20")
myArray.Add("deg")
myArray.Add("p3")
myArray.Add("30")
myArray.Add("in")
myArray.Add("p4")
myArray.Add("40")
myArray.Add("ul")
myArray.Add("p5")
myArray.Add("50")
myArray.Add("kg")
For j = 0 To myArray.Count - 1 Step 3
	If Parameter.Value(myArray(j)) Is Nothing Then
		oMyParam.UserParameters.AddByExpression(myArray(j), myArray(j + 1), myArray(j + 2))
		Parameter.Param(myArray(j)).ExposedAsProperty=True
Next
JelteDeJong
just a thought
Public Class ThisRule
	Private parameters As parameters
	Public Sub Main()
		Dim doc As Document = thisdoc.document
		If (doc.DocumentType <> DocumentTypeEnum.kAssemblyDocumentObject And
				doc.DocumentType <> DocumentTypeEnum.kPartDocumentObject) Then
			MsgBox("This is not a Part or Assembly file. Can't add parameters")
			Return
		parameters = ThisDoc.Document.ComponentDefinition.Parameters
		addParameter("p1","10","mm")
		addParameter("p2","20","deg")
		addParameter("p3","30","in")
		addParameter("p4","40" ,"ul" )
		addParameter("p5","50","kg")
	End Sub
	Private Sub addParameter(name As String, Expression As String, UnitsSpecifier As String)
		parameters.UserParameters.AddByExpression(name, Expression, UnitsSpecifier)
		Parameter.Param(name).ExposedAsProperty = True
	End Sub
End Class
Jelte de Jong
Blog: hjalte.nl - github.com
henrikubbe4438
Neat solution, I could'nt get the public variable to work, so I ditched the sub variant I was working on, thank you for clearing that up for me.
Only trouble is: Run it twice and you get double amount of parameters with "_1" at the end. Gotta have the IF-statement to check if parameter already exists.
	Public Sub Main()
			Return
	End Sub
		If parameter(name) Is Nothing Then
	End Sub
End Class
JhoelForshav
Hi @henrikubbe4438
I think you're looking for something like this?
	Public Sub Main()
			Return
	End Sub
		If parameters.OfType(Of Inventor.Parameter)().Where(Function(x) x.Name = name).Count = 0
	End Sub
End Class
henrikubbe4438
Hi there.
What does
do that
does not?
I guess the code gets a bit more stable for different situations?
JhoelForshav
Hi @henrikubbe4438
Sorry, I tried the code with
and got an error so i thought you were asking for some other way to check if the parameter exists. But now when I test your line it works fine so just ignore my reply. Your line looks cleaner 🙂
It was just a misunderstanding on my part
