why does it not finish create the Txt file ?
Darkforce_the_ilogic_guy
Advisor Advisor
I have this code this should write all the part number into an part files .. but for some reason it stop in the middle or it. antone know why and how to fix it ?
Sub Main()
	oWrite = System.IO.File.CreateText(ThisDoc.PathAndFileName(False) & ".txt")
Dim oAsmDoc As AssemblyDocument
oAsmDoc = ThisApplication.ActiveDocument
Dim oRefDocs As DocumentsEnumerator
oRefDocs = oAsmDoc.AllReferencedDocuments
Dim oRefDoc As Document
Dim wrongDisplayname As String
For Each oRefDoc In oRefDocs
	Try
			debug("1")
			oWrite.WriteLine(iProperties.Value(oRefDoc.DisplayName, "Project", "Part Number") )
			wrongDisplayname = wrongDisplayname &  vbLf & vbLf & " " & oRefDoc.FullDocumentName.ToString
	Catch
End Try
Next
MessageBox.Show(wrongDisplayname, "Title")
End Sub
Public Sub debug(txt As String)
	Trace.WriteLine("NTI : Colour " & txt)
End Sub
it stop in the midle off one
Michael.Navara
Using & for concatenation of strings is not good idea
Use StringBuilder instead
Dim oStringBuilder as New StringBuilder
oStringBuilder.AppendLine(oRefDoc.FullDocumentName)
MsgBox(oStringBuilder.ToString())
Sub Main()
	Dim oString As String = "<?xml version=""1.0""?>"
	Dim oStringBuilder As New StringBuilder
oStringBuilder.AppendLine(oString)
oWrite.WriteLine(oString)
 'oWrite.WriteLine("<?xml version=\"1.0\"?>")
'oWrite.WriteLine("<SearchParameters xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" TypeName="Connectivity.Explorer.Document.FileExplorerObject" LatestOnly="True" SearchSubfolders="True" SearchFullContent="False" IsFolder="True" Id="bc434c5c-206f-4b21-ba14-2a9d5587e1a8" xmlns="http://schemas.autodesk.com/msd/plm/SearchParameters/2009-07-23">")
'oWrite.WriteLine("  <SearchConditions>")
	Try
	'If oRefDoc.DisplayNameOverridden = True
			debug("1")
			'oWrite.WriteLine(oRefDoc.FullDocumentName.ToString)
			'oWrite.WriteLine(iProperties.Value(oRefDoc.DisplayName, "Project", "Part Number") + " OR ")
			oStringBuilder.AppendLine(iProperties.Value(oRefDoc.DisplayName, "Project", "Part Number") + " OR ")
			'wrongDisplayname = wrongDisplayname &  vbLf & vbLf & " " & oRefDoc.FullDocumentName.ToString
		'End If
	Catch
End Try
Next
oWrite.WriteLine(oStringBuilder.ToString())
End Sub
End Su
I try to make it that way , now I get an error the stringBuilder is not defind
Michael.Navara
try this full rule
Sub Main
	Dim oRefDocs As DocumentsEnumerator = oAsmDoc.AllReferencedDocuments
	Dim partNumbers As New System.Text.StringBuilder
	Dim fileNames As New System.Text.StringBuilder
		Try
			debug("1")
			Dim partNumber As String = oRefDoc.PropertySets("{32853F0F-3444-11D1-9E93-0060B03C1CA6}")("Part Number").Value.ToString()
			partNumbers.AppendLine(partNumber)
			fileNames.AppendLine(oRefDoc.FullDocumentName)
		Catch
			Logger.Error("failed " & oRefDoc.DisplayName)
		End Try
	Next
	System.IO.File.WriteAllText(ThisDoc.PathAndFileName(False) & ".txt", partNumbers.ToString())
	MessageBox.Show(fileNames.ToString(), "Title")
End Sub
End Sub
it does not do all I need it to do
I need first to inset
<?xml version="1.0"?>
<SearchParameters xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" TypeName="Connectivity.Explorer.Document.FileExplorerObject" LatestOnly="true" SearchSubfolders="true" SearchFullContent="false" IsFolder="true" Id="bc434c5c-206f-4b21-ba14-2a9d5587e1a8" xmlns="http://schemas.autodesk.com/msd/plm/SearchParameters/2009-07-23">
<SearchConditions>
<SearchCondition Value="
then
all the part number like this
Partnumer1 OR
Partnumber2 OR
partnumber 3
after all the part number I need to add this
" PromptForValue="false" PropertyKey="PartNumber">
<Type>CONTAINS</Type>
</SearchCondition>
<SearchCondition PromptForValue="false" PropertyKey="HasDrawing">
<Type>FALSE</Type>
</SearchCondition>
</SearchConditions>
<SearchLocations>
<Locations URI="vaultfolderpath:$" />
</SearchLocations>
</SearchParameters>
Michael.Navara
You can use function for formatting string. Similar to this example:
Sub main
	GetSearchStringTest()
End Sub
Sub GetSearchStringTest()
	Dim partNumbers As New List(Of String)
	partNumbers.Add("partNumber1")
	partNumbers.Add("partNumber2")
	partNumbers.Add("partNumber3")
	Dim result = GetSearchString(partNumbers)
	MsgBox(result)
End Sub
Private Function GetSearchString(partNumbers As IEnumerable(Of String)) As String
	Dim searchStringFormat As String =
            "<?xml version=""1.0""?><SearchParameters xmlns:xsd=""http://www.w3.org/2001/XMLSchema"" xmlns:xsi=""http://www.w3.org/2001/XMLSchema-instance"" TypeName=""Connectivity.Explorer.Document.FileExplorerObject"" LatestOnly=""True"" SearchSubfolders=""True"" SearchFullContent=""False"" IsFolder=""True"" Id=""bc434c5c-206f-4b21-ba14-2a9d5587e1a8"" xmlns=""http://schemas.autodesk.com/msd/plm/SearchParameters/2009-07-23""> <SearchConditions> <SearchCondition Value=""{0}"" PromptForValue=""False"" PropertyKey=""PartNumber""> <Type>CONTAINS</Type> </SearchCondition> <SearchCondition PromptForValue=""False"" PropertyKey=""HasDrawing""> <Type>False</Type> </SearchCondition> </SearchConditions> <SearchLocations> <Locations URI=""vaultfolderpath:$"" /> </SearchLocations> </SearchParameters>"
	Dim partNumbersJoined = String.Join(" ", partNumbers)
	Return String.Format(searchStringFormat, partNumbersJoined)
End Function
