Re-post - iLogic to Sort the BOM
rhasell
Advisor Advisor
rhasell
Hi all
Please don't flame me, this is a re-post from the "customization Board"
I have been searching the forum for a while now, but have been unable to find any code to sort the BOM, there are lots of snippets to sort and modify the Parts list. (Curtis Wageuespackhas done a lot on this)
Does anyone have something to sort the Assembly BOM?
Any help will be appreciated.
Thank you.
Sort parameters:
PARTS Only
"BOM Structure"
     then by
Custom Parameter "TYPE"
     Then By
Part Number
Then "Renumber" starting at 1
Reg
2026.1
rhasell
Hi there
I have been playing around a bit and have managed to get the BOM to sort on one item list only. Can someone perhaps debug my code and help with the multiple sort?
I have commented out the WORKING string, the one that I need is just above it.
Thanks guys.
' Set a reference to the assembly document.
' This assumes an assembly document is active.
Dim oDoc As AssemblyDocument
oDoc = ThisApplication.ActiveDocument
Dim SortBOM As Boolean
If MsgBox("Sort The BOM?", vbYesNo) = vbYes Then
SortBOM = True
Else
SortBOM = False
End If
' Set a reference to the BOM
Dim oBOM As BOM
oBOM = oDoc.ComponentDefinition.BOM
' Set whether first level only or all levels.
If SortBOM Then
oBOM.PartsOnlyViewEnabled = True
Else
Return
'oBOM.PartsOnlyViewEnabled = False
End If
' Make sure that the structured view is enabled.
'Set a reference to the "Structured" BOMView
Dim oBOMView As BOMView
oBOMView = oBOM.BOMViews.Item("Parts Only")
'Sort the BOM
Call oBOMView.Sort("BOM Structure",True,"TYPE",True,"Part Number",True)
''The following line works correctly
'Call oBOMView.Sort("Part Number",True)
'Re-Number the BOM
Call oBOMView.Renumber(1, 1)
Reg
2026.1
Hello
i had the exact same problem. It would not sort on 3 criteria.
Talked to one of our trainers, and he told me this is an inventor error.
What i am doing is sortin and exporting the part list on the drawing (sorting works on the drawing sheet). After this i override the assy BOM from the drawing and reorder it depending on ITEM.
I dont have the filan code yet, but i know it works. Tested part of code.
Offcourse if you do not have a drawing yet, then this is not good. In my situation I always have a drawing.
If you want i can send you my code wheen i am done...
Hope this helps.
Hey
I managed to make it work.
Look at the following thread
http://forums.autodesk.com/t5/inventor-customization/ilogic-assy-bom-sort-by-3-columns/m-p/5397643/t...
If you need any more help please tell...and dont forget to mark as solution if it's ok.
