Add Button To BOM Form
Is it possible to add a button to the Inventor BOM? Similar to adding a button to the ribbon but instead to the BOM. I want to create a button that would export a custom BOM and select only the properties I want.
Thanks in advance for any help,
Ted
Jef_E
Did you managed to do this? I'm looking for a similar solution, but then for the BOM translating.
Please kudo if this post was helpfull
Please accept as solution if your problem was solved
Inventor 2014 SP2
