RangeBox for a Sketch
J.Pelfrene
J.Pelfrene
Is there a method for getting the RangeBox of a Sketch in a PartDocument?
Sketch, Profile, RegionProperties, SketchBlock, ... None of these offer a RangeBox method. SketchEntity does, but that's for a single entity, not the entire sketch.
Thanks!
Accepted solutions (3)
JelteDeJong
You can make your own function. something like this:
Dim doc As PartDocument = ThisDoc.Document
Dim sketch As PlanarSketch = doc.ComponentDefinition.Sketches.Item(1)
Dim allMinPoints As List(Of Point2d) = sketch.
	SketchEntities.
	Cast(Of SketchEntity).
	Select(Function(e) e.RangeBox.MinPoint).
	OrderBy(Function(p) p.X).ToList()
Dim minX = allMinPoints.First().X
Dim minY = allMinPoints.OrderBy(Function(p) p.Y).First().Y
Dim allMaxPoints As List(Of Point2d) = sketch.
	SketchEntities.
	Select(Function(e) e.RangeBox.MaxPoint).
Dim maxX = allMaxPoints.Last().X
Dim maxY = allMaxPoints.OrderBy(Function(p) p.Y).Last().Y
Dim rangebox As Box2d = ThisApplication.TransientGeometry.CreateBox2d()
rangebox.MinPoint = ThisApplication.TransientGeometry.CreatePoint2d(minX, minY)
rangebox.MaxPoint = ThisApplication.TransientGeometry.CreatePoint2d(maxX, maxY)
sketch.Edit()
sketch.SketchLines.AddAsTwoPointRectangle(rangebox.MinPoint, rangebox.MaxPoint)
 Edit: I found a bug after posting and i solved it.
Jelte de Jong
Blog: hjalte.nl - github.com
J.Pelfrene
Thank you!
I thought of doing it this way too, but was afraid it would be computationally expensive. It is not!
And interesting to learn something from your code as well.
Cheers
j_weber
@JelteDeJong
Great code.
Is it also possible to change the color of the range box to for example orange or to change the style to construction
Jörg Weber
CAD Systemtechniker für AutoCAD, Inventor, Vault
JelteDeJong
you can try it like this:
	SketchEntities.
	SketchEntities.
sketch.Edit()
Dim lines = sketch.SketchLines.AddAsTwoPointRectangle(rangebox.MinPoint, rangebox.MaxPoint)
Dim red = ThisApplication.TransientObjects.CreateColor(255, 0, 0)
For Each line As SketchLine In lines
	line.Construction = True
	line.OverrideColor = red
Next
Jelte de Jong
j_weber
Thanks a lot 🙂
Jörg Weber
