How to change font in a sketch on all parts in an assembly
randersonSCS1
Message 1 of 11
randersonSCS1
I am trying to write a rule that cycles through all parts in an assembly and changes the font on a sketch that is used for an emboss on the part.
There are two emboss features generated from 1 sketch. The emboss features should always be named "LASER LABEL A1" and "LASER LABEL A2". The sketch with two text boxes is named "LASER LABEL SKETCH".
I would like to be set the font to Stencil and change the font size to .25 inches.
Previously I worked with someone that wrote code to cycle through parts and suppress an emboss feature, I'm thinking that code could be helpful here. I'm new to iLogic and inventor API, trying to learn!
Sub Main()
    'define the assembly document
	Dim oAsmDoc As AssemblyDocument
    oAsmDoc = ThisDoc.Document
	'Get user input
	If RuleArguments(oBool) <> Nothing
		oBool = RuleArguments(oBool)
	Else
		oBool = InputRadioBox("Toggle TOP A1 Emboss", "TOP A1 OFF", "TOP A1 ON", True, Title :="TOP A1 EMBOSS")
	'define the assembly component definition
	Dim oAsmDef As AssemblyComponentDefinition
	oAsmDef = oAsmDoc.ComponentDefinition
	'define the leaf occurences of the assembly
	Dim oLeafOccs As ComponentOccurrencesEnumerator
	oLeafOccs = oAsmDef.Occurrences.AllLeafOccurrences
	'define the occurences
	Dim oOcc As ComponentOccurrence
	'Define a part component definiton
	Dim oPCD As PartComponentDefinition
	'Iterate through the assembly
	For Each oOcc In oLeafOccs
		'Set the part component definition equal to the current occurrence
		oPCD = oOcc.Definition
		'Define and set an emboss features collection
		Dim oEFs As EmbossFeatures
		oEFs = oPCD.Features.EmbossFeatures
		'Define an emboss feature
		Dim oEmboss As EmbossFeature
		If oBool = True Then
			Try
				'Suppress Emboss1
				oEmboss = oEFs.Item("Emboss1")
                oEmboss.Suppressed = True
			Catch
			End Try
		'Checking to see if user input a no
		ElseIf oBool = False
			Try
				'Unsuppress Emboss1
                oEmboss.Suppressed = False
			Catch
			End Try
		'Checking to see if something went wrong
		Else
			'do nothing
	Next
	RuleParametersOutput()
	InventorVb.DocumentUpdate()
End Sub
I have found a few similar solutions working to format text in a part, but I'm struggling to locate the call the text from the part sketch. Here are a couple links
Solved: Change text with iLogic - Autodesk Community - Inventor
Solved: Create Text/sketch on a face in a assembly with iLogic - Autodesk Community - Inventor
Solved: Change Font for all text-elements - Autodesk Community - Inventor
Replies (10)
Message 2 of 11
dalton98
You could insert this into where the 'oPCD as ComponentDefinition' line is:
'Dim oDoc As PartDocument = ThisApplication.ActiveDocument
'Dim oPCD As ComponentDefinition = oDoc.ComponentDefinition
Dim oSketch As Sketch
oSketch = oPCD.Sketches.Item("LASER LABEL SKETCH")
Dim oTextBox As TextBox
For Each oTextBox In oSketch.TextBoxes
Dim oText As String = oTextBox.Text
Dim oFormattedText As String = "<StyleOverride FontSize='0.25'>" & oText & "</StyleOverride>"
oSketch.TextBoxes.Item(1).FormattedText = oFormattedText
Next
ThisApplication.CommandManager.ControlDefinitions.Item("AppLocalUpdateCmd").Execute
Message 3 of 11
randersonSCS1
That got me a little bit closer. I am able to change the font size on the parts, but the emboss feature will not update until manually selected (double click to edit the feature, then click okay) in the individual parts!
I tried InventorVb.DocumentUpdate(), is there a way to call the emboss to update?
Here is my code now:
Sub Main()
			Try
				Dim oFormattedText As String = "<StyleOverride FontSize='.25'>" & oText & "</StyleOverride>"
				Next
			Catch
			End Try
	Next
End Sub
Message 4 of 11
dalton98
Take out the
 and replace it with this: (hopefull it force updates it)
Dim oEmbossFeature As EmbossFeature
For Each oEmbossFeature In oPCD.Features.EmbossFeatures
oEmbossFeature.Suppressed = True
oEmbossFeature.Suppressed = False
Next
Message 5 of 11
randersonSCS1
Good idea, unfortunately turning suppression state on and off doesn't rebuild the emboss feature. I tested it on a part level too, no dice!
From the individual part level UI the "Rebuild All" button works to update the emboss, BUT it doesn't work from the assembly level!
Message 6 of 11
dalton98
u said editing worked. Try this:
oOcc.Edit
oOcc.ExitEdit(ExitTypeEnum.kExitToTop)
Message 7 of 11
dalton98
is this the problem  your getting?
https://knowledge.autodesk.com/support/inventor/troubleshooting/caas/sfdcarticles/sfdcarticles/Inven...
If so rebuild all seems to usually work. (Place at end of code)
ThisApplication.CommandManager.ControlDefinitions.Item("AssemblyRebuildAllCmd").Execute
Message 8 of 11
randersonSCS1
The parts were edited, but the emboss still did not update.
Is there a way to use the rebuild command? I tried a couple things "ThisDoc.Document.Rebuild()" seems to rebuild the assembly, not the individual parts like I need.
I was also trying "ThisDoc.AllReferencedDocuments.Rebuild()" but that gives me an error
I was getting ideas from this topic:
https://forums.autodesk.com/t5/inventor-ilogic-and-vb-net-forum/ilogic-rebuild-part-sub-assembly-reg...
Message 9 of 11
randersonSCS1
Sorry, I missed this reply before I posted mine. I'm not getting the "update flash symbol" on the parts when I use the rebuild all command, so I don't think that is the issue.
I tried "AssemblyRebuildAllCmd", that didn't change anything.
Message 10 of 11
dalton98
YOu would need to set it up like "ThisDoc.AllReferencedDocuments.Item(1).Reubild()"
If the ".rebuild" works you could just incorperate it into the code like this:
Dim oPCDD As Document
oPCDD = oPCD.Document
oPCDD.Rebuild()
'oPCDD.Rebuild2()
Message 11 of 11
randersonSCS1
That works!
Here is my final code
Sub Main()
			Try
				Dim oFormattedText As String = "<StyleOverride Font='Stencil' FontSize='0.25'>" & oText & "</StyleOverride>"
				'FONT size is in cm!
				oSketch.TextBoxes.Item(2).FormattedText = oFormattedText
				Next
			Catch
			End Try
	oPCDD.Rebuild()
	'oPCDD.Rebuild2()
Next
End Sub
