Raise window
Raise window
GeorgK
Advisor Advisor
Raise window
GeorgK
Hello together,
i would like to set automatically a lot of holes. I have a sketch with a lot of points. How could I get all the points which are in a raised window
(by pressing the left mouse button and drawing a window while keeping the mousebutton pressed)?
Thank you
Georg
AlexFielder
You can do this with the CommandManager.Pick method and the SelectionFilterEnum.kSketchPointFilter filter for it:
http://help.autodesk.com/view/INVNTOR/2018/ENU/?guid=GUID-60D6E12D-1471-4AD9-9748-67D7EE63333D
GeorgK
Hello Alex,
do you have a sample for me?
Thank you Georg
Owner2229
I guess Alex meant something like this:
Dim oComps As Inventor.ObjectCollection = ThisApplication.TransientObjects.CreateObjectCollection
While True
	Dim oComp As Object = ThisApplication.CommandManager.Pick(Inventor.SelectionFilterEnum.kSketchPointFilter, "Select some points.")
	' If nothing gets selected we're done here
	If IsNothing(oComp) Then Exit While
	oComps.Add(oComp)
End While
If oComps.Count = 0 Then Exit Sub
'List through the points For Each oSP As SketchPoint In oComps 'Do something with the point Next
Consider using "Accept as Solution" / "Kudos" if you find this helpful.
Mike
"Always code as if the guy who ends up maintaining your code will be a violent psychopath who knows where you live." - John F. Woods
AlexFielder
That's the ticket @Owner2229! 🙂
@GeorgK did you click the link I posted? There are a whole bunch of samples on that page:
Check out my other thread to set up searching the API documentation from within Google Chrome:
https://forums.autodesk.com/t5/inventor-customization/searching-the-online-api-help-without-having-t...
GeorgK
Thank you very much for your help. I added the search function to my browser.
