How to search for a ipart component in an assembly with a keyword using ilogic
Message 1 of 1
I tried using the code:
Dim oAsmCompDef As AssemblyComponentDefinition
        oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition
        'Iterate through all of the occurrences
        Dim oOccurrence As ComponentOccurrence
        For Each oOccurrence In oAsmCompDef.Occurrences
            Dim oName As String
            If oOccurrence.Name.contains("family name") And oOccurrence.Name.contains("instance number") Then
                oName = oOccurrence.Name
                If condition Then
                    oOccurrence.suppress
                Else
                    oOccurrence.unsuppress
                Exit For
        Next
this returns the name successfully only if the component is a normal part.
If it is an ipart, it returns "Nothing". How can I also get  the component name for an ipart
Replies (0)
