Message 1 of 14
Question on Running commands using API: how to provide 2 inputs through API?
- Mute
- Permalink
- Report
Hi
Brian Ekins gave a good information on how to Run Commands Using the API. And he also shows API can provide one sets of input to the command.
In my case, the Inventor command "analyze interference" need two sets of inputs. I tried to feed the commands with two selectset input throght API (see attached code). But the command looks like only take one set of them.So the behavior is not what I want.
So if it is possible, how to provide 2 set of pre-defined input to inventor commands throught API?
Thank you very much for the help.
Limin
Limin
Inventor pro 2023 64 bit update 5.3; Windows 11 pro 64 bit version 24H2; Office 2013 64 bit
Limin
