Question on Running commands using API: how to provide 2 inputs through API?
liminma8458
Message 1 of 14
liminma8458
Hi
Brian Ekins gave a good information on how to Run Commands Using the API. And he also shows API can provide one sets of input to the command.
In my case, the Inventor command "analyze interference" need two sets of inputs. I tried to feed the commands with two selectset input throght API (see attached code). But the command looks like only take one set of them.So the behavior is not what I want.
So if it is possible,  how to provide 2 set of pre-defined input to inventor commands throught API?
Thank you very much for the help.
Limin
Limin
Inventor pro 2023 64 bit update 5.3; Windows 11 pro 64 bit version 24H2; Office 2013 64 bit
Download iCable in App Store to Create Cables Easily
Replies (13)
Message 2 of 14
gavbath
I believe the problem you are having here is because the dialog box still shows and wants you to select "OK."
As you can't provide the "OK" via the API, you can't complete the command.
In Brian Ekins' blog post he said this:
" Most commands, even if they support pre-selection of entities, will still allow additional selection so they will still require user input.  For example the Fillet command will take any pre-selected edges as input but still displays the dialog to allow the user to select more edges and specify any other options."
I don't think you can finish the analyze interference command through the API call.
Gavin Bath
MFG / CAM Technical Specialist
Design and Motion Blog
Facebook | Twitter | LinkedIn | YouTube
Message 3 of 14
gavbath
Why not use the method that is already provided in the API rather than running the command using CommandManager?
AssemblyComponentDefinition.AnalyzeInterference( Set1 As ObjectCollection, [Set2] As Variant ) As InterferenceResults
Gavin Bath
Message 4 of 14
liminma8458
The program runs well, but only take the first set to do the analysis. What I want is to analyse the first set against the second set.
Limin
Message 5 of 14
liminma8458
I want the highlight effect of the interference volumn as in the command. The API does not provide that
Limin
Message 6 of 14
gavbath
Get the InterferenceResult.InterferenceBody (which is a SurfaceBody) and display it using ClientGraphics?
Gavin Bath
Message 7 of 14
liminma8458
Just wonder how to reach the object of "InterferenceResult.InterferenceBody", the Interferenceresult only shows centroid, occurrenceone,occurrencetwo, type and volume (double type). oResults.InterferenceBody returns error. as attached
How to do that? thanks
Limin
Message 8 of 14
gavbath
Try this:
Public Sub ShowInterference()
    Dim oDoc As AssemblyDocument
    Set oDoc = ThisApplication.ActiveDocument
    Dim oCompDef As ComponentDefinition
    Set oCompDef = oDoc.ComponentDefinition
    Dim oSelect1 As ComponentOccurrence
    Set oSelect1 = oDoc.SelectSet.Item(1)
    Dim oSelect2 As ComponentOccurrence
    Set oSelect2 = oDoc.SelectSet.Item(2)
    Dim oCheckSet As ObjectCollection
    Set oCheckSet = ThisApplication.TransientObjects.CreateObjectCollection
    Call oCheckSet.Add(oSelect1)
    Call oCheckSet.Add(oSelect2)
    Dim oIntBody As SurfaceBody
    Set oIntBody = oDoc.ComponentDefinition.AnalyzeInterference(oCheckSet).Item(1).InterferenceBody
    ' Create the ClientGraphics object.
    Set oClientGraphics = oCompDef.ClientGraphicsCollection.Add("Sample3DGraphicsID")
        ' Create a new graphics node within the client graphics objects.
        Dim oSurfacesNode As GraphicsNode
        Set oSurfacesNode = oClientGraphics.AddNode(1)
        Dim oBody As SurfaceBody
        Set oBody = oIntBody
        ' Create client graphics based on the transient body
        Dim oSurfaceGraphics As SurfaceGraphics
        Set oSurfaceGraphics = oSurfacesNode.AddSurfaceGraphics(oBody)
        ' Update the view to see the resulting curves.
        ThisApplication.ActiveView.Update
End Sub
Select two components that interfere and then runthe routine. After you have run it, hide the 2 components and you'll see the interference body left over.
Gavin Bath
Message 9 of 14
liminma8458
The above line does NOTwork. InterferenceBody is not recognized.  "oDoc.ComponentDefinition.AnalyzeInterference(oCheckSet).Item(1) " only has centroid, occurrenceone,occurrencetwo, type and volume (double).
More advise?
Limin
Message 10 of 14
gavbath
I wouldn't post code on here if I hadn't tested it myself.... 🙂
2. Select them both
3. Run macro, interference is left behind
Gavin Bath
Message 11 of 14
liminma8458
I add a definition line in your code: Dim oClientGraphics As ClientGraphics.
And create two parts as yours and make an assembly, want to repeat your success, still not working.
Stop at (see attached error massage): XXXXXX.....InterferenceBody
I am running on Inventor 2011. But I don't think this is a new feature if there is any.
Limin
Message 12 of 14
gavbath
Very strange. I should have mentioned that I am using Inventor 2013 but I don't know if the InterferenceBody is new since 2011. I can't imagine it would be.
Maybe post your dataset and I'll try it in 2013.
Gavin Bath
Message 13 of 14
gavbath
I spoke to soon..... The InterferenceBody was new in Inventor 2012 sorry.
Gavin Bath
Message 14 of 14
liminma8458
Yes. The code works for Inventor 2013, but not 2011.
So I still have the question: is it possible to provide 2 inputs to run Inventor commands using API?     ^_^
Limin
