Question about adding drawing template with code
frederic.vandenplas
frederic.vandenplas
I've recently discovered that another template opens when i use this code, previously only Standard.idw was in the template folder, now i have added another one with a name (alphabetically before Standard.idw (for example NewTemplate.idw)
Dim oDrawDoc As DrawingDocument = InvApp.Documents.Add(DocumentTypeEnum.kDrawingDocumentObject, InvApp.FileManager.GetTemplateFile(DocumentTypeEnum.kDrawingDocumentObject)
Is this as designed that through API, the first drawing (alphabetically) , will be the template used by this line of code.
I know how to avoid this and define the template path string, so i don't need any code 🙂
If you think this answer fullfilled your needs, improved your knowledge or leads to a solution,
please feel free to "kudos"
chandra.shekar.g
Autodesk Support
Autodesk Support
Hi @frederic.vandenplas,
A new template is created and called it as "NewStandard.idw".
On running following VBA code,
MsgBox (ThisApplication.FileManager.GetTemplateFile(kDrawingDocumentObject))
A message box is popped up and showing the path of "Standard.idw".
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
frederic.vandenplas
if i use your/my code, this is what i get, so it's more a random thing?
This is not expected behaviour if you compare it to the GUI
chandra.shekar.g
Autodesk Support
Autodesk Support
Drawing template path can be changed to desired location.
Go to "Tools" tab -> click on "Application Options" button -> a dialog will appear. In that, click on "File" tab -> under "Default Templates" -> template can be changed to desired location as shown in below image.
After changing template path, click on "General" tab -> under "Startup" -> check "Startup action"-> enable "New from template", new template can be specified from template path.
Following message box will appear with new template path.
Please feel free to contact if there is any doubt.
If solves problem, click on "Accept as solution" / give a "Kudo".
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
frederic.vandenplas
Hi @chandra.shekar.g
I understand your explanation, but what if i don't use a startup action, and i really don't use it in real life situations!
On the other hand, if i don't use this settings, api does not look at these settings too, because suddenly my code opens the "wrong" template.
So there must be an api explanation for this strange behaviour???
chandra.shekar.g
Autodesk Support
Autodesk Support
Even after disabling Startup action, template file path can be retrieved from the VBA code.
Please find the following API to play with startup action settings.
ThisApplication.GeneralOptions.StartupActionType = kNoStartupAction
ThisApplication.GeneralOptions.StartupNewFileTemplateName = ""
ThisApplication.GeneralOptions.StartupProjectFileName = ""
If solves your problem, click on "Accept as solution" / give a "Kudo".
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
