Putting Object Occurence in a table/Parts List
RNDinov8r
Message 1 of 11
RNDinov8r
So, I have come upon this link which has the code that allows you to put an occurence description/number in a BOM Balloon call out. It works great. What I haven't been able to find is a way to take those occurences and put them in a table or parts list. Has anyone ever attemped this? I have attached a picture of what I am trying to accomplish. The table shown was created by "brute force". I even found code which allows for the creation of a custom table on the fly, but I lack the VBA knowledge to be able to tell the table to put the "Occurence Tracking" data (shown as sensor description in the table in the image) in the correct column.
Here's what I have so far for the Table Creation.
Public Sub CreateCustomTable()
' Set a reference to the drawing document.
' This assumes a drawing document is active.
Dim oDrawDoc As DrawingDocument
Set oDrawDoc = ThisApplication.ActiveDocument
' Set a reference to the active sheet.
Dim oSheet As Sheet
Set oSheet = oDrawDoc.ActiveSheet
' Set the column titles
Dim oTitles(1 To 2) As String
oTitles(1) = "Part Number"
oTitles(2) = "Sensor Description"
' Set the contents of the custom table (contents are set row-wise)
Dim oContents(1 To 16) As String
oContents(1) = "FS-N11CP"
oContents(2) = "Bowl Part In Place"
oContents(3) = "FS-N11CP"
oContents(4) = "Bowl Part In Place"
oContents(5) = "OISP-014"
oContents(6) = "Gripper Rotary 180°"
oContents(7) = "OISP-014"
oContents(8) = "Gripper Rotary Home"
oContents(9) = "D-M9PVSAPC"
oContents(10) = "Gripper Open"
oContents(11) = "D-M9PVSAPC"
oContents(12) = "Gripper Closed"
oContents(13) = "D-M9PSAPC"
oContents(14) = "Gripper @ Home"
oContents(15) = "D-M9PSAPC"
oContents(16) = "Gripper @ Pick"
' Set the column widths (defaults to the column title width if not specified)
Dim oColumnWidths(1 To 2) As Double
oColumnWidths(1) = 5
oColumnWidths(2) = 8
' Create the custom table
Dim oCustomTable As CustomTables
Set oCustomTable = oSheet.CustomTables.Add("Input Locations & Descriptions", ThisApplication.TransientGeometry.CreatePoint2d(15, 15), _
2, 8, oTitles, oContents, oColumnWidths)
' Where "_2" is the number of columns and "8" is the number of rows
' Change the 3rd column to be left justified.
oCustomTable.Columns.Item(3).ValueHorizontalJustification = kAlignTextLeft
' Create a table format object
Dim oFormat As TableFormat
Set oFormat = oSheet.CustomTables.CreateTableFormat
' Set inside line color to red.
oFormat.InsideLineColor = ThisApplication.TransientObjects.CreateColor(255, 0, 0)
' Set outside line weight.
oFormat.OutsideLineWeight = 0.1
' Modify the table formats
oCustomTable.OverrideFormat = oFormat
End Sub
Replies (10)
Message 2 of 11
chandra.shekar.g
Autodesk Support
Autodesk Support
@RNDinov8r,
Try the following VBA code to below custom table.
    Dim oSheet As Sheet
    Dim oTitles(1 To 3) As String
    oTitles(3) = "Occurance Tracking"
    Dim oContents(1 To 24) As String
    oContents(3) = "30"
    oContents(4) = "FS-N11CP"
    oContents(5) = "Bowl Part In Place"
    oContents(6) = "30"
    oContents(8) = "Gripper Rotary 180°"
    oContents(9) = "29"
    oContents(10) = "OISP-014"
    oContents(11) = "Gripper Rotary Home"
    oContents(12) = "29"
    oContents(13) = "D-M9PVSAPC"
    oContents(14) = "Gripper Open"
    oContents(15) = "28"
    oContents(16) = "D-M9PVSAPC"
    oContents(17) = "Gripper Closed"
    oContents(18) = "28"
    oContents(19) = "D-M9PSAPC"
    oContents(20) = "Gripper @ Home"
    oContents(21) = "27"
    oContents(22) = "D-M9PSAPC"
    oContents(23) = "Gripper @ Pick"
    oContents(24) = "27"
    Dim oColumnWidths(1 To 3) As Double
    oColumnWidths(1) = 4.5
    oColumnWidths(2) = 5.5
    oColumnWidths(3) = 5.75
    oDrawDoc.StylesManager.ActiveStandardStyle.ActiveObjectDefaults.TableStyle.HeadingGap = 0.1
                                        3, 8, oTitles, oContents, oColumnWidths)
    oCustomTable.Columns.Item(1).ValueHorizontalJustification = kAlignTextLeft
    oCustomTable.Columns.Item(2).ValueHorizontalJustification = kAlignTextLeft
    oFormat.OutsideLineWeight = 0.05
End Sub
Please feel free to contact if there is any queries.
If solves problem, click on "Accept as solution" / give a "Kudo".
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
Message 3 of 11
RNDinov8r
Chandra,
I'm sorry, I wasn't clear. Thank you for looking into this, though. I am trying to avoid the "brute force" method by having to type in the Sensor Description and Part No, since there will always be different quantities and descriptions on different machines. I want the p/n and the "sensor description" (which is part of occurrence tracking VB in the link in my initial post) to get pulled into the parts list, rather than me have to manually go in and change this particular portion of code for every assembly (Given that some of our machines use 50-100 sensors, you can see manually tracking would be an issue) or sub assembly:
I dont' actually care about the "item number" (27, 28, 29, & 30) but I do care about "part number" and "sensor description". I just want them to be auto populated rather than manually entered (as shown in the above code lines).
I have attached another picture as well so you can see where I change the "Occurence Number" to a "Sensor Description" in the assembly. this is how I give the information to my controls department so they know how to write the code for the PLC...essentially, I am creating a tag for them to use. This infomation gets put into a parts list (what I'm trying to solve above) that ultimately gets exported to excel, and they then dump it into their PLC code. The idea is to reduce manually re-entering tags and data once it has been created.
Message 4 of 11
chandra.shekar.g
Autodesk Support
Autodesk Support
@RNDinov8r,
Based on above image, occurrence names of sensor contains part number + ':' + sensor description. With this assumption, I tried some below VBA code. Assumed that Drawing Document always contains assembly document. VBA code runs only for Drawing document.
Sub Main()
    Dim oDoc As DrawingDocument
    Set oDoc = ThisApplication.ActiveDocument
    Dim oAsmDoc As AssemblyDocument
    Set oAsmDoc = oDoc.ActiveSheet.DrawingViews.Item(1).ReferencedDocumentDescriptor.ReferencedDocument
    Dim oDef As AssemblyComponentDefinition
    Set oDef = oAsmDoc.ComponentDefinition
    Dim sensorCnt As Integer
    Dim oContents() As String
    Dim IsInteger As Boolean
    Dim LArray() As String
    Dim occ As ComponentOccurrence
    For Each occ In oDef.Occurrences
        LArray = Split(occ.Name, ":")
        IsInteger = ConvertToInteger(LArray(1))
        If IsInteger = False Then
            sensorCnt = sensorCnt + 1
    Next
    If sensorCnt > 0 Then
        sensorCnt = sensorCnt * 2
        ReDim oContents(sensorCnt - 1) As String
        Dim i As Integer
        i = 0
                oContents(i) = LArray(0)
                oContents(i + 1) = LArray(1)
                i = i + 2
        Next
    Dim oSheet As Sheet
    Set oSheet = oDoc.ActiveSheet
    oDoc.StylesManager.ActiveStandardStyle.ActiveObjectDefaults.TableStyle.HeadingGap = 0.1
    Set oCustomTable = oSheet.CustomTables.Add("Input Locations & Descriptions", ThisApplication.TransientGeometry.CreatePoint2d(45, 15), _
                                        2, sensorCnt / 2, oTitles, oContents, oColumnWidths)
End Sub
Function ConvertToInteger(v1 As String) As Boolean
    On Error GoTo 100:
     Dim i As Integer
     i = CInt(v1)
     ConvertToInteger = True
     Exit Function
100:
     ConvertToInteger = False
End Function
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 5 of 11
RNDinov8r
That was exactly what I was trying to do. Really appreciate that. I have a long way to go it appears before I get to programming like that! Again, much appreciated.
Message 6 of 11
RNDinov8r
So, I have been playing around Chandra and I discovered that this code works great for an Assembly/Drawing where I need to evaluate occurrence labels that are only within that assembly (first layer)...however, I discovered, if I run this on an assembly with sub assemblies which contain the occurrence labels, it does not find them. It is not apparent to me in the code why it would not burrow down a level or two levels or further for that matter. Would a traversing subroutine, similar to what is found here be used?
Message 7 of 11
MechMachineMan
Try changing both instances of
oDef.Occurrences
to
oDef.Occurrences.AllLeafOccurrences
and see if that works for you.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Message 8 of 11
RNDinov8r
I now get this a run-time '9' error.
It is specific to:
I have tried other numbers and qty does not seem to matter.
Message 9 of 11
MechMachineMan
My assumption would be that it's telling you some occurrence names do not have a ":" character in them, so it's throwing it off.
Justin K
Message 10 of 11
chandra.shekar.g
Autodesk Support
Autodesk Support
@RNDinov8r,
It is assumed that every occurrence in assembly is containing ":" character. Try the below VBA code to avoid that error.
Sub Main()
    For Each occ In oDef.AllLeafOccurrences
On Error Resume Next
LArray = Split(occ.Name, ":") IsInteger = ConvertToInteger(LArray(1)) If IsInteger = False Then sensorCnt = sensorCnt + 1 End If Next If sensorCnt > 0 Then sensorCnt = sensorCnt * 2 ReDim oContents(sensorCnt - 1) As String Dim i As Integer i = 0 For Each occ In oDef.Occurrences LArray = Split(occ.Name, ":") IsInteger = ConvertToInteger(LArray(1)) If IsInteger = False Then oContents(i) = LArray(0) oContents(i + 1) = LArray(1) i = i + 2 End If Next End If ' Set a reference to the active sheet. Dim oSheet As Sheet Set oSheet = oDoc.ActiveSheet ' Set the column titles Dim oTitles(1 To 2) As String oTitles(1) = "Part Number" oTitles(2) = "Sensor Description" ' Set the column widths (defaults to the column title width if not specified) Dim oColumnWidths(1 To 2) As Double oColumnWidths(1) = 4.5 oColumnWidths(2) = 5.5 oDoc.StylesManager.ActiveStandardStyle.ActiveObjectDefaults.TableStyle.HeadingGap = 0.1 ' Create the custom table Dim oCustomTable As CustomTable Set oCustomTable = oSheet.CustomTables.Add("Input Locations & Descriptions", ThisApplication.TransientGeometry.CreatePoint2d(45, 15), _ 2, sensorCnt / 2, oTitles, oContents, oColumnWidths) ' Change the 3rd column to be left justified. oCustomTable.Columns.Item(1).ValueHorizontalJustification = kAlignTextLeft oCustomTable.Columns.Item(2).ValueHorizontalJustification = kAlignTextLeft ' Create a table format object Dim oFormat As TableFormat Set oFormat = oSheet.CustomTables.CreateTableFormat ' Set inside line color to red. oFormat.InsideLineColor = ThisApplication.TransientObjects.CreateColor(255, 0, 0) ' Set outside line weight. oFormat.OutsideLineWeight = 0.05 ' Modify the table formats oCustomTable.OverrideFormat = oFormat End Sub Function ConvertToInteger(v1 As String) As Boolean On Error GoTo 100: Dim i As Integer i = CInt(v1) ConvertToInteger = True Exit Function 100: ConvertToInteger = False End Function
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 11 of 11
RNDinov8r
that did the trick. I am going to play around with this a little more on various models, but I think this does the trick. Really appreciate that.
