Put sub-assembly in color in drawing
inventor4578
inventor4578
I would like to know if it possible by iLogic to put in color (red) the current sub-assembly of the sheet (i have 1 sub-assembly by sheet), in a general view (ISO) of the top assembly, to see quickly where is this sub-assembly in the main.
- I have 1 sub-assembly by sheet (The sub is already in a assembly, in the top assembly...)
- I put a ISO view, and i select this view
- I run the macro, the macro look for the current sheet attached model
- It search on the ISO view the corresponding assembly
- It put in RED color line
Thank you very much !
daltonNYAW9
I created something similar to this a while ago. The main difference is instead of changing the line's layer, I would hold <CTRL> then change the "edge properties" color. It worked faster this way.
Tweeked that rule:
First manually add a layer w/ a specific name ("Item Detail" for this rule)
Also, assumed the sub-assembly is always the first drawing view
' Get the transaction manager from the application
Dim oTxnMgr As TransactionManager
oTxnMgr = ThisApplication.TransactionManager
' Start a regular transaction
Dim oTxn As Transaction
oTxn = oTxnMgr.StartTransaction(ThisDoc.Document, "transaction")
Dim oDDoc As DrawingDocument = ThisDoc.Document
Dim oTopAssyView As DrawingView = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingViewFilter, "Select Assembly View")
Dim oTopAssyViewBrowserNode As BrowserNode = oDDoc.BrowserPanes("Model").GetBrowserNodeFromObject(oTopAssyView).Parent
Dim oTopAssyDoc As AssemblyDocument = oTopAssyView.ReferencedDocumentDescriptor.ReferencedDocument
Dim oSheet As Sheet = oDDoc.ActiveSheet
Dim oSubAssyView As DrawingView = oSheet.DrawingViews(1)
Dim oSubAssyDoc As AssemblyDocument = oSubAssyView.ReferencedDocumentDescriptor.ReferencedDocument
'expand sheet nodes to get assembly nodes
ThisApplication.CommandManager.DoSelect(oTopAssyView.Parent)
ThisApplication.CommandManager.ControlDefinitions.Item("AppBrowserExpandChildrenCmd").Execute
Dim lines As ObjectCollection = ThisApplication.TransientObjects.CreateObjectCollection
For Each oOcc As ComponentOccurrence In oTopAssyDoc.ComponentDefinition.Occurrences.AllReferencedOccurrences(oSubAssyDoc)
	Dim oOccBrowserNodeDef As BrowserNodeDefinition = oTopAssyDoc.BrowserPanes.GetNativeBrowserNodeDefinition(oOcc)
	For Each oBrowserNode As BrowserNode In oTopAssyViewBrowserNode.AllReferencedNodes(oOccBrowserNodeDef)
		oDDoc.SelectSet.Clear
		oBrowserNode.DoSelect
		If oDDoc.SelectSet.Count <> 0
			ThisApplication.CommandManager.ControlDefinitions.Item("SelectAsEdgesCtxCmd").Execute
			For i = 1 To oDDoc.SelectSet.Count
				lines.Add(oDDoc.SelectSet.Item(i))
			Next
		End If
	Next
Next
'collapse all browser nodes
ThisApplication.CommandManager.ControlDefinitions.Item("AppBrowserCollapseAllCmd").Execute
'layer you want it changed to
Dim oLayer As Layer = oDDoc.StylesManager.Layers.Item("Item Detail")
oSheet.ChangeLayer(lines, oLayer)
oTxn.End
Stakin
how reset to default layer?
daltonNYAW9
@Stakin change the 'oLayer' value.
Dim oLayer As Layer = oDDoc.StylesManager.Layers.Item("Visible (ANSI)")
'or
oLayer = Nothing
Stakin
thanks it works for every curvesegment ,but can't work for changelayer method.
daltonNYAW9
Yeah changing the layers for each curve segment is a bit finicky. Here's how you could do it without messing with the layers, just the line "properties" in the drawing:
And to reset the properties you can just right click on the view's assembly node > properties... > color "by layer"
Dim oTopAssyView As DrawingView = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingViewFilter, "Select Assembly View, Hold <CTRL> for multiple")
Dim oSubAssyDoc As Document = oSubAssyView.ReferencedDocumentDescriptor.ReferencedDocument
	Next
Next
'unselect sheet
ThisApplication.CommandManager.DoUnSelect(oSheet)
'change line color command
ThisApplication.CommandManager.ControlDefinitions.Item("DrawingObjectPropertiesCtxCmd").Execute
oTxn.End
