Inventor API - Python
sundaram1087
sundaram1087
Hi All
I try to Explore possibilities of Automating the Inventor Using Python.
Could you please share if there is any Reference documents or any sample application or any links, by that Am able to Understand and Proceed On this
Regards
Shunmugasundaram
JelteDeJong
I did some tests in the past to see if it was possible. I figured that it was possible but I never used it. My test code can be found on GitHub.
You also might want to check this link:
https://forums.autodesk.com/t5/inventor-ilogic-and-vb-net-forum/importing-an-assembly-document-into-...
Jelte de Jong
Blog: hjalte.nl - github.com
