Purge unused materials and styles
andrewiv
Advisor Advisor
andrewiv
I'm looking to write an iLogic rule that will go through a document and purge all of the unused materials and styles.  Ideally I would like this to handle any type of document whether it be ipt, iam, or idw but if I have to write a separate rule for each I'm OK with that.
I've done some searching and not found anything that I can use yet.  I was wondering if anyone has figured this out yet?
Andrew In’t Veld
Designer / CAD Administrator
MechMachineMan
Here's a starting point for you. Works on drawings. I don't imagine for parts and iams it would look very different.
			Sub PurgeStyles()
				Dim oStyles As DrawingStylesManager
				oStyles = oDoc.StylesManager
				Dim noneleft As Boolean
				noneleft = True
				Dim ostyle As Style
				Do While (noneleft)
					noneleft = False
					For Each ostyle In oStyles.Styles
						If (ostyle.StyleLocation = kLocalStyleLocation) And (ostyle.InUse = False) Then
							ostyle.Delete
							noneleft = True
					Next
				Loop
			End Sub
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
andrewiv
This did not work for me.  I did a simple test and started a new drawing, created a new balloon style and ran your code.  After running it the new balloon style is still there even though it isn't used anywhere.  When I manually go to the manage tab and hit the purge command, the new style shows up.
Andrew In’t Veld
MechMachineMan
Ok?
Convert it to VBA, put it in the VBA environment in inventor, add a watch to break when true for when oStyle.Name = "your new balloon style name".
Step through the code after that point, see what flags its skipping/tripping.
Modify it from there.
Justin K
james.collinsPWQR2
Try this:
Dim oDoc As DrawingDocument = ThisApplication.ActiveEditDocument
Dim oStyles As DrawingStylesManager = oDoc.StylesManager
Dim noneleft As Boolean = True
Dim ostyle As Style
Do While (noneleft)
	noneleft = False
		If ostyle.StyleLocation = 51202 And ostyle.InUse = False Then
			' uncomment next line to see styles being deleted
'			MsgBox(ostyle.Name)
			ostyle.Delete
			noneleft = True
	Next
Loop
Cheers,
James
