PROBLEM WITH SHARING TEMPLATES WITH ILOGIC - GLOBAL FORMS
U22233272
U22233272
Good day community, I am new to the ILOGIC configuration. I find it a very useful tool and the problem I have is the following:
I have a drawing template .idw which I configured with a pop-up window (attached photos) which I saved as a template. Everything is fine when I use it on my PC, however, when I share the template to another PC, the pop-up window does not seem to copy the rules but not the global forms.
I already tried to save everything as packaged files but still. Everything is copied down to the rules except the global forms. What I can do?
this appears on my pc:
However, on a colleague's PC it does not appear, everything appears except that global shapes pop-up window.
Curtis_Waguespack
Hoi @U22233272
The global forms are located in the Design Data folder.
Usually somewhere like this: C:\Users\Public\Documents\Autodesk\Inventor 2023\Design Data\iLogic\UI
Typically we place the entire Design Data folder on a shared location and point all the users to that folder, so that everyone is using the same files, including the Global Forms
If the users do not have access to the same folder, then we need to distribute the forms to this location
To find your global form files location, right click on the global forms ilogic panel and choose "open Containing folder"
I hope this helps.
Curtis
