Using a paramerter for Patterns.AddCircular Count
brianA32ZM
brianA32ZM
Is there a way to use a parameter, PatternFrameEndQty in this case, for the circular count when using Patterns.AddCircular?
Patterns.AddCircular("Component Pattern - Frame End", "Frame End (Top)",
                     PatternFrameEndQty, 180.000000 deg, "", "X Axis")
j-robertson
Are you attempting to link the parameter, or just use the value?
Maybe use "PatternFrameEndQty.Value" if unlinked is fine.
Michael.Navara
You can use parameter name as you used, but the parameter units must be set to "ul".
