On Error Resume Next
bob_clark5J5M8
bob_clark5J5M8
Hi all, I have a piece of code that shows a dialogue box to select a folder and enter a file name. My problem is that it uses the "On error resume next" line of code to function correctly.
I'd like to remove this line and still trap the error if someone cancels out of the save or does not enter a file name.
'define the active document
oDoc = ThisDoc.Document
'create a file dialog box
Dim oFileDlg As Inventor.FileDialog = Nothing
InventorVb.Application.CreateFileDialog(oFileDlg)
'set the directory to open the dialog at
oFileDlg.InitialDirectory = ThisDoc.WorkspacePath()
'set the file name string to use in the input box
oFileDlg.FileName = iProperties.Value("Project", "Part Number")
'work with an error created when cancelling the save
oFileDlg.CancelError = True
'specify the file dialog as a save dialog
oFileDlg.ShowSave()
'catch an empty string in the input
If Err.Number <> 0 Then
Return
ElseIf oFileDlg.FileName <> "" Then
f = oFileDlg.FileName
'save the file
oDoc.SaveAs(f, False)
Curtis_Waguespack
Hi @bob_clark5J5M8
I think this will work.  I didn't test well, so post back if it does not
I hope this helps.
Curtis
oFileDlg.ShowSave()
If oFileDlg.FileName = Nothing Then
	msgbox("no file selected")
	Return
	MsgBox("selected: " & oFileDlg.FileName)
	'save the file
	oDoc.SaveAs(oFileDlg.FileName, False)
bob_clark5J5M8
Perfect 🙂
