Printing with iLogic
karthur1
Mentor Mentor
Message 1 of 9
karthur1
I am trying to print via iLogic. In my printer driver there is a ARCH D page size that I would like to use.  I can get my code to work with Tabloid or Letter size, but not the ARCH D.
Here is what I see in my printer settings.
And this is the code I have so far.
Dim oDrgDoc As DrawingDocument
oDrgDoc = ThisApplication.ActiveDocument
' Set reference to drawing print manager' DrawingPrintManager has more options than PrintManager' as it's specific to drawing document
Dim oDrgPrintMgr As DrawingPrintManager
oDrgPrintMgr = oDrgDoc.PrintManager
'Set the printer name. Either Change this to match the system printer name, or change the system printer to this name
'(comment this line to use Default printer Or assign another one).
oDrgPrintMgr.Printer = "PDF"
oPrintMgr = ThisApplication.ActiveDocument.PrintManager
'oPrintMgr.ColorMode = kPrintGrayScale
oPrintMgr.ColorMode = kPrintColorPalette
'oPrintMgr.Orientation = kPortraitOrientation
oPrintMgr.Orientation = kLandscapeOrientation
oPrintMgr.PaperSize = kPaperSizeArchD
'oPrintMgr.PaperHeight = 36
'oPrintMgr.PaperWidth = 24
oPrintMgr.ScaleMode = Inventor.PrintScaleModeEnum.kPrintBestFitScale
oPrintMgr.SubmitPrint
 I think the issue is the line
I just don't know how to tell it to use "ARCH D".
Replies (8)
Message 2 of 9
bradeneuropeArthur
modified:
oDrgPrintMgr.Printer = "Microsoft Print to PDF"'"PDF"
'oDrgPrintMgr.PaperSize
'oDrgPrintMgr = ThisApplication.ActiveDocument.PrintManager
'oDrgPrintMgr.ColorMode = kPrintGrayScale
oDrgPrintMgr.ColorMode = kPrintColorPalette
'oDrgPrintMgr.Orientation = kPortraitOrientation
oDrgPrintMgr.Orientation = kLandscapeOrientation
oDrgPrintMgr.PaperSize = Inventor.PaperSizeEnum.kPaperSizeArchD
'oDrgPrintMgr.PaperHeight = 36
'oDrgPrintMgr.PaperWidth = 24
oDrgPrintMgr.ScaleMode = Inventor.PrintScaleModeEnum.kPrintBestFitScale
oDrgPrintMgr.SubmitPrint
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 9
Frederick_Law
Message 4 of 9
karthur1
I got it to work using kPaperSizeCustom.  NOTE: units are in cm.
'Set Paper Size. Height x Width units are in centimeters.
oPrintMgr.PaperSize = kPaperSizeCustom
oPrintMgr.PaperHeight = 91.44
oPrintMgr.PaperWidth = 60.96
'Set Color Mode
'Set Orientation
' Set to print all sheets.
	oPrintMgr.PrintRange = kPrintAllSheets
	'oPrintMgr.PrintRange = kPrintCurrentSheet
oPrintMgr.ScaleMode = kPrintBestFitScale
Message 5 of 9
karthur1
@Frederick_Law
@bradeneuropeArthur
I thought I had it figured out, but I have another related question.  "What-if" I wanted to print using the Windows default system printer?  I thought that I could just comment out the line
'oDrgPrintMgr.Printer = "\\SRV-VM-RUS-DC2\FMI Engineering - BW Ricoh MP C4504EX PCL6"
When I do that, it will use which ever printer was used to print the last file.  It might be PDF or a different printer.
I want it to use the printer set as Default in Windows.  Is there a way to do that?
Message 6 of 9
Frederick_Law
Part of the problem is Windows.
Default is "last printer".
You might need to hard code the printer.
Now you can setup (copy) a printer and rename it in Windows (like "IV Default").
Use that as "Default" in your code.
You can also add form so user can change default printer and paper size.
Message 7 of 9
Frederick_Law
I did not use printer to make PDF.
I used IV PDFAddIn.
Public Sub PublishPDF()
    ' Get the PDF translator Add-In.
    Dim PDFAddIn As TranslatorAddIn
    Set PDFAddIn = ThisApplication.ApplicationAddIns.ItemById("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")
    'Set a reference to the active document (the document to be published).
    Dim oDocument As Document
    Set oDocument = ThisApplication.ActiveDocument
    Dim oContext As TranslationContext
    Set oContext = ThisApplication.TransientObjects.CreateTranslationContext
    oContext.Type = kFileBrowseIOMechanism
    ' Create a NameValueMap object
    Dim oOptions As NameValueMap
    Set oOptions = ThisApplication.TransientObjects.CreateNameValueMap
    ' Create a DataMedium object
    Dim oDataMedium As DataMedium
    Set oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
    ' Check whether the translator has 'SaveCopyAs' options
    If PDFAddIn.HasSaveCopyAsOptions(oDocument, oContext, oOptions) Then
        ' Options for drawings...
        oOptions.value("All_Color_AS_Black") = 0
        oOptions.value("Remove_Line_Weights") = 0
        ' Resolutions: 150, 200, 300, 400, 600, 720, 1200, 2400, 4800
        oOptions.value("Vector_Resolution") = 1200
        oOptions.value("Sheet_Range") = kPrintAllSheets
        'oOptions.Value("Custom_Begin_Sheet") = 2
        'oOptions.Value("Custom_End_Sheet") = 4
    Dim DrawingName As String
    DrawingName = " "
    Dim DrawingPath As String
    DrawingPath = " "
    Dim DrawingFullName As String
    DrawingFullName = oDocument.FullFileName
    Call SplitPath(DrawingFullName, DrawingPath, DrawingName)
    'Check if folder exist, create if not
    On Error Resume Next
    Dim fs, f
    Set fs = CreateObject("Scripting.FileSystemObject")
    Set f = fs.CreateFolder(DrawingPath + "PDF")
    'Set the destination file name
    oDataMedium.Filename = DrawingPath + "PDF\" + DrawingName + ".pdf"
    'Publish document.
    Call PDFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)
End Sub
Message 8 of 9
karthur1
That's what I was afraid of. I am trying to make a generic Global form for everyone here to use.  There are several users that use different printers, so I have to create a iLogic rule that has the name of their "Default" printer in the rule.
If I had a way for them to pick from a list of available printers, that might work too.
This is what my form looks like so far.  I have a different rule for each button here.
Message 9 of 9
Frederick_Law
You'll need to get a printer list from Windows.
