print excluded sheets (pdf) using API
How to print excluded sheets to PDF via API. Is there any name value map for this?
MechMachineMan
Use print manager API object to access things req'd for printing.
Use API help/"Programming Help" from inventor/the search feature on the forums to find out how to do this all without relying on forum replies
Dim oDoc as Document
oDoc = ThisApplication.ActiveDocument
Dim oSheet As Sheet
For Each oSheet in oDoc.Sheets
     oSheet.Activate
     If oSheet.ExcludeFromCount = True
              'Run print to pdf code here
     End if
Next
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
thanks for your replay, but this will work only when you want to print individual sheets as individual pdf files. And Iam using the same for that purpose in my Addinns. My requirement is to us the function for all Sheet and sheets in range. which is not mentioned in any of the API helps and forum threads.
MechMachineMan
Are you actually PRINTING to pdf, or are you just exporting using the translator add-in?
(Does the pdf have layers or not?)
Justin K
MechMachineMan
One thing you could do is just iterate through the sheets and flip the excluded status temporarily so that you can print the originally excluded sheets as the non-excluded sheets.
Also. ThisApplication.ActiveDocument.DrawingPrintManager might be something to look at. [Which is easily found through Programming help]
Justin K
drawing print manager will work if it is a print job. I am using translator addin to create the pdf with various options as required. presently I am using a workaround to do the same.
Dim oSheet As Sheet
            If Me.CheckBoxExcluded.Checked = True Then
                For Each oSheet In oDrgDoc.Sheets
                    If oSheet.ExcludeFromPrinting = True Then
                        oSheet.ExcludeFromPrinting = False
                Next
' and as below
ElseIf RB_SheetsInRange.Checked = True Then
                    Dim i As Integer
                    i = Me.NumericUpDownStart.Value
                    Do
                        oDrgDoc.Sheets(i).Activate()
                        oDoc = oDrgDoc.ActiveSheet.DrawingViews.Item(1).ReferencedDocumentDescriptor.ReferencedDocument
                        strfilename = oDoc.PropertySets.Item("Design Tracking Properties").Item("Part Number").Value
                        oDataMedium.FileName = Me.PathTextBox.Text & "\" & strfilename & ".pdf"
                        PDFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)
                        i = i + 1
                    Loop Until i = Me.NumericUpDownEnd.Value + 1
 above is a part of my code which is using the workaround
