Pratt Truss usign ilogic and frame generator
paulo.figueiredo
paulo.figueiredo
Hi All,
I created a skeleton model for a Pratt Truss with parameters to drive the amount of bays (4,6,8 and 10).
This skeleton was imported inside an assembly file in order to apply the frame generator and then create an illogic rule to suppress and unsuppress members as needed depending on the amount of bays.
However, the frame generator doesn't update according to the new skeleton model, when the number of bays change.
Please see images 01 to 03 attached.
Does anyone know if the frame generator doesn't respond favourably to changes when this type of rule is applied to it?, is this an Inventor limitation?
Any feedback is much appreciated.
Tony_Yates
Have you tried "rebuild all"
