Ilogic display name
Ilogic display name
KenVaessen
Ilogic display name
KenVaessen
I'm using the next Ilogic rule in a part.
'Title instead Of autorename
Dim oDoc As Document = ThisApplication.ActiveDocument
oDoc.DisplayName = iProperties.Value("Project", "Part Number") & "/"& iProperties.Value("Project", "REVISION NUMBER") & " - " & iProperties.Value("Project", "Description")
iProperties.Value("Summary", "Title") = iProperties.Value("Project", "Part Number") & "/"& iProperties.Value("Project", "REVISION NUMBER") & " - " & iProperties.Value("Project", "Description")
The problem is that he also renames the displayname of the Assembly where this part is in. Can anybody help me to solve this problem?  He must only use this Rule in the part. The assembly must run the same rule but with the properties of the assembly.
JelteDeJong
Does this work for you.
Dim oDoc As Document = ThisDoc.Document
Jelte de Jong
Blog: hjalte.nl - github.com
KenVaessen
Works great! Thanx (Dank u)!
KenVaessen
Is it also possible to get the filenumber for a drawing?
so instead of "Project", "Part Number" I want the filename
JelteDeJong
you can try this:
Dim fullFileName As String = oDoc.fullfilename
Dim fi As IO.FileInfo = New IO.FileInfo(oDoc.FullFileName)
Dim title As String = fi.Name & "/"& iProperties.Value("Project", "REVISION NUMBER") & " - " & iProperties.Value("Project", "Description")
oDoc.DisplayName = title
iProperties.Value("Summary", "Title") = title
Jelte de Jong
