Hi @claudio.ibarra. The short answer is no. We do not yet have full access to all of those settings by code yet.
We do have access to these setting though:
DrawingSettings.CustomPropertySourceFile
ThisDrawing.ResourceFileName
ThisDrawing.KeepExtraResources
Edit: If we set those setting the way we want them in our drawing template, then every new drawing we create using that template will use those settings to automatically copy those properties from the model into the drawing when we place the first view of a model into that new drawing. If you currently have a drawing open, and you already have model view in it, then you open those settings, you will be able to see any custom iProperties in that model. However, you will not be able to see all other current or future custom properties from all other model files that are not in that drawing at that time...so you may have to update those settings from time to time.
We can create our own custom iLogic rules that will copy specific properties from 'the model' to the drawing. But if we use our own rules, then it is up to us to manage how/when they get ran. But rules like this would only be useful after the first view of a model has been placed into the drawing, not when the drawing is first created. There is no event listed in the iLogic Event Triggers dialog for when we place the first view into a new drawing either, so that would need to be 'handled' by a custom Inventor API event handler, such as what are used within an Inventor add-in.
There is a command button in the ribbon for updating the properties that were copied over into the drawing by those built-in settings, and we can simulate clicking that command button by code, but it is not ideal yet. There is no Inventor API method for that task, that I know of, yet.
Below is some code that can simulate clicking that button, and clicking the yes button in the dialog.
ThisApplication.CommandManager.ControlDefinitions.Item("UpdateCopiedModeliPropertiesCmd").Execute2(False)
AppActivate(ThisApplication.Caption)
System.Windows.Forms.SendKeys.SendWait("y")
ThisApplication.UserInterfaceManager.DoEvents
Wesley Crihfield
(Not an Autodesk Employee)
