Is it possible to develop a application in WinUI or UWP (Add-in or Standalone) for Inventor?
infoQ82EV
Message 1 of 1
infoQ82EV
I am looking for a kind of list of possible/supported UI-Frameworks beside of the programm-language c# that are able or also maybe not able to use when it comes to Autodesk Inventor Add-in and Standalone helper tool development for automating and improving construction workflow.
I would like to know if there is anything speeking against developing a UWP/WinUI/Maui/Uno(?) for developing an Application that should connect to the Autodesk Inventor (Professional 2021 at the moment) API or not. I actually only seen Winforms (quite outdated at this date) and WPF Applications but was thinking about if there is any reason speaking against this mentioned "newer" "pretty" UI-Frameworks to also use enchanced Toolkits as well.
Thank you for your answer!
Kind regards!
Replies (0)
