Place iLogic components; renamed files are deleted
Hi
While placing an assembly using the "Place iLogic components" command, files that have just be copied and renamed in the process are deleted as soon as I click in the host assemby window, or on the place iLogic component form OK button.
I noticed this his happening since i'm using Inventor 2014; never occured before with Inventor 2012.
Does anyone has a clue of how I could resolve this?
Thanks in advance.
Yves
adam.nagy
Autodesk Support
Autodesk Support
I tried it in Inventor 2014 SP1 and I could not reproduce it.
Does it happen to any assembly on your machine?
Could you create a video showing all the steps and what exactly happens?
Cheers,
Adam Nagy
Autodesk Platform Services
Hi Adam, thank you for your inquiry.
I have found that ETO is responsible for that faulty behavior.
Even if I'm not using  "Intent" for the moment, the ETO addin is loaded. Unchecking "load on startup", close and launch inventor did the trick.
Somehow, ETO interfere with the "Place iLogic component" command...(?)
Yves Gingras
