Ilogic rule to color my layer based on two first numbers. In drawing.2
Hallo,
I have already used this rule but it works only on the exact same part name. How can i change this rule to work for me for example "55" String.Left ("string", 2 ).
rule i used:
(<!)Dim drawViews As DrawingView
For Each drawViews In ThisApplication.ActiveDocument.ActiveSheet.DrawingViews
occ3 = drawViews.ReferencedDocumentDescriptor.ReferencedDocument.ComponentDefinition.Occurrences.ItemByName("55 02 0201 C:1")
Dim newColor3 As Color
newColor3 = ThisApplication.TransientObjects.CreateColor(0,255,255)
Dim drawcurves3 As DrawingCurvesEnumerator
drawcurves3 = drawViews.DrawingCurves(occ3)
Dim drawCurve3 As DrawingCurve
For Each drawCurve3 In drawcurves3
      drawCurve3.Color() = newColor3
Next
Next
TNX
Lamrini
adam.nagy
Autodesk Support
Autodesk Support
Hi Lamrini,
You would just need to iterate through all the components whose name you want to check, then collect them if they meet the requirement.
I wrote a sample for that:
http://adndevblog.typepad.com/manufacturing/2014/03/get-occurrences-whose-name-starts-with-a-certain...
I hope this helps.
Cheers,
Adam Nagy
Autodesk Platform Services
Hello Adam,
Can it also work in a drawing file? problem is that I need to unhide specific part based on  their description. And change layer type for example.
I sometimes have 50 parts that I need to manually unhide, it takes forever!
Does VBA, Ilogic or API have a solution for that?
Attached an example.
TNX
Lamrini.
