ilogic and excel
ilogic and excel
Message 1 of 14
ilogic and excel
I have and ilogic rule that reads an excel file. On one machine with an external hard drive, file path ("E:\xxx") there is no problem. On another machine reading from the server, file path ("E:\xxx") I get the following error:
System.Runtime.InteropServices.COMException (0x80030002):  could not be found. (Exception from HRESULT: 0x80030002 (STG_E_FILENOTFOUND))
   at Microsoft.Office.Interop.Excel.ApplicationClass.get_LanguageSettings()
   at iLogic.GoExcel.ExcelAppGetLanguageID(Application app)
   at iLogic.GoExcel.SetCurrentSheet(String fileName, String sheetName)
   at iLogic.GoExcel.FindRow(String fileName, String sheetName, Object[] sizeArgs)
   at LmiRuleScript.Main()
   at Autodesk.iLogic.Exec.AppDomExec.ExecRuleInAssembly(Assembly assem)
   at iLogic.RuleEvalContainer.ExecRuleEval(String execRule)
Can someone explain why?
Replies (13)
Message 2 of 14
philippe.leefsma
Hi
Can you post the iLogic code, maybe it will give more clue? Did you determine what is the iLogic call that is problematic?
Did you try with VBA directly? You could determine if it is iLogic related or more general.
Another thing you could try is re-installing Excel on the machine that has the issue.
Here is a VBA sample you can run from Inventor (you need to add a reference to Microsoft Excel Object Lib):
Sub TestOpenXls()
    Dim xlsApp As Excel.Application
    Set xlsApp = CreateObject("Excel.Application")
    xlsApp.Visible = True
    Dim wb As Excel.workbook
    Set wb = xlsApp.Workbooks.Open("X:\TEMP\adn.xlsx")
End Sub
Philippe.
Philippe Leefsma
Developer Technical Services
Autodesk Developer Network
Message 3 of 14
liminma8458
I got similar problem. How can you solve the last problem.
my problem is like that: I run iLogic under Inventor 2016 and Excel 2013. All other machine run well except one machine have such error:
System.Runtime.InteropServices.COMException (0x8002801D): Library not registered. (Exception from HRESULT: 0x8002801D (TYPE_E_LIBNOTREGISTERED))
   at Microsoft.Office.Interop.Excel._Application.get_LanguageSettings()
   at iLogic.GoExcel.get_CellValue(String fileName, String sheetName, String cellAddress)
Look like problem comes from "GoExcel.CellValue()". I can even open the Excel in iLogic without problem.
Attached is my code and error message.
Thanks for your help.
Limin
Limin
Inventor pro 2023 64 bit update 5.3; Windows 11 pro 64 bit version 24H2; Office 2013 64 bit
Download iCable in App Store to Create Cables Easily
Message 4 of 14
Owner2229
Hi, does the path to the Excel file vary for each computer?
You can try the code below:
---Start of iLocic code---
Dim oExcel As Object
Dim oWB As Object
Dim oWS As Object
Dim ExcelFile As String
oExcel = CreateObject("Excel.Application")
'Set your Excel document here: oWB = oExcel.Workbooks.Open("E:\cc_data.xls") oExcel.Visible = False oExcel.DisplayAlerts = False oWS = oWB.Sheets(1) oWB.Activate 'First is row, then column: oWS.Cells(1, 1).Value = "Test" oWB.Close (True) oExcel.Quit
---End of iLocic code---
Or the same in VBA ( no need for adding a reference to Microsoft Excel Object Lib. It even causes problems if someone has different version of Excel).
---Start of VBA code---
Dim oWB As Object
Dim oWS As Object
Set oExcel = CreateObject("Excel.Application")
'Set your Excel document here: Set oWB = oExcel.Workbooks.Open("E:\cc_data.xls") oExcel.Visible = False oExcel.DisplayAlerts = False Set oWS = oWB.Sheets(1) oWB.Activate 'First is row, then column: oWS.Cells(1, 1).Value = "Test" oWB.Close True oExcel.Quit
---End of VBA code---
Consider using "Accept as Solution" / "Kudos" if you find this helpful.
Mike
"Always code as if the guy who ends up maintaining your code will be a violent psychopath who knows where you live." - John F. Woods
Message 5 of 14
liminma8458
I use "GoExcel.open("cc_data.xls"). It did open the file. But the following "GoExcel.CellValue()" does not work.
Limin
Message 6 of 14
Owner2229
I know, but since it is not working for you now, we're suggesting you another way of doing this.
Just try it.
Btw. This is how the GoExcel.Value comand should look like:
GoExcel.CellValue("A1") = "Test"
Or:
Dim row As Integer
row = 1
GoExcel.CellValue("A" & row) = "Test"
Mike
Message 7 of 14
liminma8458
very basic one:
icross_bar_dia=GoExcel.CellValue("cc_data.xls", "Sheet1", "cross_bar_dia")
icross_bar_lgth=GoExcel.CellValue("cc_data.xls", "Sheet1", "cross_bar_lgth")
see attached
Thank you so much!
Limin
Message 8 of 14
Owner2229
In the CellValue you have to specify the cell, not the file, nor sheet and not even whatever is the third.
You should have the GoExcel opening on first line so it should look like below. I dont know in which cells you have the data, so you have to modify this.
The "cc_data.xls" part must reffer full path to the document so it will be something like "C:\WhatEverPath\cc_data.xls".
Uncomment the "GoExcel.Save" if you're writing something in the file, so it will save.
GoExcel.Open("cc_data.xls", "Sheet1")
icross_bar_dia = GoExcel.CellValue("A1")
icross_bar_lgth = GoExcel.CellValue("B1")
'GoExcel.Save
GoExcel.Close
Mike
Message 9 of 14
liminma8458
The third parameter is the cell name in Excel file.
I have the codes exactly on other machines which also run Inventor 2016 and Excel 2013. All of other machines work fine except one.
So I am very puzzle.
Limin
Message 10 of 14
Owner2229
There may be an error in your code that didnt reveal on the other PCs. So you should try the codes above ^^.
Do you have instaled the same service packs on all the PCs?
Try this code and let me know if it works:
GoExcel.Open("C:\SetYourPathHere\cc_data.xls", "Sheet1")
icross_bar_dia = GoExcel.CellValue("cross_bar_dia")
icross_bar_lgth = GoExcel.CellValue("cross_bar_lgth")
MsgBox("Dia: " & icross_bar_dia & vblf & "Lgth: " & icross_bar_lgth)
GoExcel.Close
Mike
Message 11 of 14
Tony_Yates
Hi
Did you ever resolve this issue?
We have now got the same problem on one out of 5 machines. Only recently happened it was working fine last week.
The machines that work ok are running inventor 2019 and excel 2016. The one that stopped working had inventor 2019 and excel 2010, we upgraded the excel to 2016 but didn't make a difference.
Hope you can help.
Message 12 of 14
liminma8458
I don't remember how I resolved the problem exactly. But we don't use .open or .close syntaxs finally.
Try to set up a system variable UseLibXL as follow to see whether it solves your problem. It should also make you iLogic run faster.
https://forums.autodesk.com/t5/inventor-customization/ilogic-run-much-longer-in-windows-10-and-multi...
Good luck
Limin
Message 13 of 14
Tony_Yates
Uninstalled "foxit" now working fine.
Message 14 of 14
liminma8458
Yes. You remind that. The "Foxit" indeed ever caused the problem to us. Maybe it automatically puts some plugin in the excel.
Glad to hear you solved the problem
Limin
