pdf with revision
pdf with revision
info
Message 1 of 16
pdf with revision
info
Hello everyone
I have an ilogic rule that creates PDF files from an iam.
now I also want to have an overhaul.
I have added revision but unfortunately this is not working.
Does anyone know what I did wrong
DI-A-0030-00026 SHU.idw (Sheet-1) rev1
Sub Main()
'define the active document as an assembly file
Dim oAsmDoc As AssemblyDocument
oAsmDoc = ThisApplication.ActiveDocument
Dim oAsmName As String
oAsmName = Left(oAsmDoc.DisplayName, Len(oAsmDoc.DisplayName) -4)
'check that the active document is an assembly file
If ThisApplication.ActiveDocument.DocumentType <> kAssemblyDocumentObject Then
MessageBox.Show("Please run this rule from the assembly file.", "iLogic")
Exit Sub
'get user input
RUsure = MessageBox.Show ( _
"This will create a PDF file for all of the asembly components that are sheet metal." _
& vbLf & "This rule expects that the part file is saved." _
& vbLf & " " _
& vbLf & "Are you sure you want to create PDF for all of the assembly components?" _
& vbLf & "This could take a while.", "iLogic - Batch Output PDFs ",MessageBoxButtons.YesNo)
If RUsure = vbNo Then
Return
Else
oPath = ThisDoc.Path
Dim oDataMedium As DataMedium
oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
oRevNum = iProperties.Value("Project", "Revision Number")
oContext = ThisApplication.TransientObjects.CreateTranslationContext
oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
oOptions = ThisApplication.TransientObjects.CreateNameValueMap
ExPath = "C:\Users\j.kleijnjans\Documents\PDF_DXF_STP\" & "PDF_DXF_STP"
If Not System.IO.Directory.Exists(ExPath) Then
System.IO.Directory.CreateDirectory(ExPath)
    ' Define the active document As an Assembly file
        oIdwPathName = ThisDoc.ChangeExtension(".idw")
    'ThisApplication.CommandManager.ControlDefinitions.Item("AppFileCloseCmd").Execute
            ' Look at the files referenced by the assembly
    Dim oRefDocs As DocumentsEnumerator
    oRefDocs = oAsmDoc.AllReferencedDocuments
    Dim oRefDoc As Document
    ' Work the the drawing files for the referenced models. This expects that the model has a drawing of the same path and name
    For Each oRefDoc In oRefDocs
        idwPathName = Left(oRefDoc.FullDocumentName, Len(oRefDoc.FullDocumentName) - 3) & "idw"
        ' Check to see that the model has a drawing of the same path and name
        If(System.IO.File.Exists(idwPathName)) Then
            Dim oDrawDoc As DrawingDocument
            oDrawDoc = ThisApplication.Documents.Open(idwPathName, True)
i = 1
'blader door sheets en exporteer
For Each oSheet In oDrawDoc.Sheets
ThisApplication.ActiveDocument.Sheets.Item(i).Activate
ThisApplication.ActiveView.Fit
Dim oDoc As DrawingDocument
oDoc = ThisApplication.ActiveDocument
Dim iSheet As Sheet
iSheet = oDoc.ActiveSheet
Dim oFileName As String
oFileName = Left(oDoc.DisplayName, Len(oDoc.DisplayName) - 4)'0
oPDFAddIn = ThisApplication.ApplicationAddIns.ItemById _
("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")
oDocument = ThisApplication.ActiveDocument
Dim lPos As Long
Dim rPos As Long
Dim sLen As Long
Dim sSheetName As String
Dim iSheetNumber As Integer
Dim ExportFolder As String
'find the seperator in the sheet name:number
lPos = InStr(iSheet.Name, ":")
'find the number of characters in the sheet name
sLen = Len(iSheet.Name)
'find the sheet name
sSheetName = Left(iSheet.Name, lPos -1)
'find the sheet number
iSheetNumber = Right(iSheet.Name, sLen -lPos)
'set PDF Options
'If oPDFAddIn.HasSaveCopyAsOptions(oDataMedium, oContext, oOptions) Then
oOptions.Value("All_Color_AS_Black") = 0
oOptions.Value("Remove_Line_Weights") = 1
oOptions.Value("Vector_Resolution") = 400
oOptions.Value("Sheet_Range") = Inventor.PrintRangeEnum.kPrintSheetRange
oOptions.Value("Custom_Begin_Sheet") = iSheetNumber
oOptions.Value("Custom_End_Sheet") = iSheetNumber
'oDataMedium.FileName = ExPath & "\" & "(" & sSheetName & "-" & ").pdf"
oDataMedium.FileName = ExPath & "\" & oFileName & " " & "(" & sSheetName & "-" & i & ")" & "_" & oRevNum & ".pdf"
'Publish document
oPDFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)
'sheet index ophogen
i=i+1
    Next
            oDrawDoc.Close        ' Close the file
    Next
'idw van opstaande samenstelling exporteren
        If(System.IO.File.Exists(oIdwPathName)) Then
            oDrawDoc = ThisApplication.Documents.Open(oIdwPathName, True)
i = 1
Dim iSheet As Sheet
oFileName = Left(oDoc.DisplayName, Len(oDoc.DisplayName)-4)
Dim lPos As Long
Dim rPos As Long
Dim sLen As Long
'set PDF Options
'Set the PDF target file name
oDataMedium.FileName = ExPath & "\" & oFileName & " " & "(" & sSheetName & "-" & i & ")"& "_" & oRevNum &".pdf"
'oDataMedium.FileName = ExPath & "\" & oFileName & " " & "(" & sSheetName & "-" & i & ").pdf"
'Publish document
i=i+1
    Next
'MessageBox.Show("PDF-bestanden opgeslagen")
MessageBox.Show("PDF FILES ARE READY")
proceed1 :
End Sub
Replies (15)
Message 2 of 16
marcin_otręba
when you want to access iproperties from file different that document from which ilogic rule is run, than you need to do it through doc.property sets.item...
Try this:
Sub Main()
Exit Sub
'get user input
& vbLf & " " _
	Return
Else
     export (oRefDoc,ExPath)
    Next
export (oAsmDoc, ExPath)
proceed1 :
End Sub
Sub export(doc As Document, ExPath As String)
	 idwPathName = Left(doc.FullDocumentName, Len(doc.FullDocumentName) - 3) & "idw"
			i = 1
				Dim iSheet As Sheet
				Dim lPos As Long
				Dim rPos As Long
				Dim sLen As Long
				sSheetName = Split(iSheet.Name,":")(0)
				iSheetNumber = Split(iSheet.Name,":")(1)
				'set PDF Options
				'oRevNum = iProperties.Value("Project", "Revision Number")
				oRevNum=doc.PropertySets.Item("Inventor Summary Information").Item("Revision Number").Value
				'Publish document
				oPDFAddIn.SaveCopyAs(oDrawDoc, oContext, oOptions, oDataMedium)
				i = i + 1
			Next
            oDrawDoc.Close(True)        ' Close the file
End Sub
Hi, maybe you want to check my apps:
DrawingTools   View&ColoringTools   MRUFolders
Message 3 of 16
info
Perfectly what I was looking for.
One more question
If there is no revevision, can the pdf be saved as:
If there is a revision, save the file as
Greet Jos
Message 4 of 16
WCrihfield
Your file system may not like having the dot/period ( . ) in the middle of the file name.
Perhaps either removing the drawing files extension, or replacing that dot with an underscore ( _ ) or other non-filesystem-offending characters would help.
Wesley Crihfield
(Not an Autodesk Employee)
Message 5 of 16
marcin_otręba
sure,
replace:
with:
if oRevNum<>”” then
oDataMedium
else
\" & oFileName & " " & "(" & sSheetName & "-" & i & ")" & ".pdf"
end if
Message 6 of 16
info
It works perfect
Message 7 of 16
marcin_otręba
nice to hear that. Can you accept my answer as solution then ?
Message 8 of 16
Sprocket1077
Sorry.
Wrong destination.
Message 9 of 16
Sprocket1077
Hi you all.
I like this rule a lot, but I need a little update too.
First I would like it to apply the rule to the assembly drawing file as well as the parts. Witch I think it doesn't.
I would like it to create a PDF sub folder in the assembly folder, not in C:/user/... or dedicated folder.
I would like it to create also the step file of the parts in the same folder.
I would like it to apply the drawing revision number to the pdf file even if the revision is 0.
I would like it to apply the same revision number to the step files.
And I also would like the suffix scheme naming to looks like -R00. I mean ''-R'' with always double digits even if the drawing revision number is ''-R1'' (Should result as -R01).
I know you are very good at this, me not.
Thanks a lot.
Message 10 of 16
WCrihfield
Hi @Sprocket1077.  I think I have something that may work for your needs.  It's a fairly large code, because it's a fairly large and complex task.  I put the two main export processes (PDF & STEP) into two different Sub routines that can be called by the main Sub.  One thing that may cause problems in this process is if your Revision number is a Letter instead of a Number.  In your post, it looked like you were referring to a zero (0) in your Revision number.  Is that zero always present, or is it just 'empty' when there is no revision?  If it is 'empty' then we may have to adjust this code a bit to put that initial zero in place when it is found to be empty, just to be safe.  I am retrieving that revision number as an Integer, then using a technique to convert it to a String with double digits, as part of the revision text in the file name.
Let me know how this works for you, of if this isn't what you were looking for.
Sub Main
	If ThisApplication.ActiveDocumentType <> DocumentTypeEnum.kAssemblyDocumentObject Then
		MsgBox("An Assembly Document must be active for this rule to work. Exiting.",vbOKOnly+vbCritical, "WRONG DOCUMENT TYPE")
		Exit Sub
	Dim oADoc As AssemblyDocument = ThisAssembly.Document
	oDirChar = System.IO.Path.DirectorySeparatorChar
	oPath = System.IO.Path.GetDirectoryName(oADoc.FullFileName) & oDirChar & "PDF & STEP" & oDirChar
	'get file name without path and without file extension
	oAsmName = System.IO.Path.GetFileNameWithoutExtension(oADoc.FullFileName)
	'gets Rev Number as Integer (Won't work if using Letters!)
	Dim oRevNum As Integer = oADoc.PropertySets(1).Item("Revision Number").Value
	Dim oRev As String = "-R" & oRevNum.ToString("00")
	If Not System.IO.Directory.Exists(oPath) Then
		System.IO.Directory.CreateDirectory(oPath)
	oNewPDFName = oPath & oAsmName & oRev & ".pdf"
	ExportToPDF(oADoc, oNewPDFName)
	oNewSTEPName = oPath & oAsmName & oRev & ".stp"
	ExportToSTEP(oADoc, oNewSTEPName)
	For Each oRefDoc As Document In oADoc.AllReferencedDocuments
		oRefName = System.IO.Path.GetFileNameWithoutExtension(oRefDoc.FullFileName)
		oRevNum = oADoc.PropertySets(1).Item("Revision Number").Value
		oRev = "-R" & oRevNum.ToString("00")
		oNewPDFName = oPath & oRefName & oRev & ".pdf"
		ExportToPDF(oRefDoc, oNewPDFName)
		oNewSTEPName = oPath & oRefName & oRev & ".stp"
		ExportToSTEP(oRefDoc, oNewSTEPName)
	Next
	MsgBox("All new PDF & STEP files were saved to:" & vbCrLf & oPath, , "FINISHED")
End Sub
Sub ExportToPDF(oDoc As Document, oNewFileName As String)
	Dim oDDoc As DrawingDocument
	If oDoc.DocumentType = DocumentTypeEnum.kDrawingDocumentObject Then
		oDDoc = oDoc
	Else
		oDrawingFile = System.IO.Path.ChangeExtension(oDoc.FullFileName, ".idw")
		If System.IO.File.Exists(oDrawingFile) Then
			oDDoc = ThisApplication.Documents.Open(oDrawingFile, False)
		Else
			Exit Sub
	'get the PDF Translator Add-in
	Dim oPDFAddin As TranslatorAddIn
	For Each oAddin As ApplicationAddIn In ThisApplication.ApplicationAddIns
		If oAddin.DisplayName = "Translator: PDF" Then
			oPDFAddin = oAddin
	Next
	'Create the variables needed by the Translator Add-in
	oTO = ThisApplication.TransientObjects
	oContext = oTO.CreateTranslationContext
	oOptions = oTO.CreateNameValueMap
	oDataMedium = oTO.CreateDataMedium
	oDataMedium.FileName = oNewFileName
	'Check to see if the PDF already exists, if it does, ask if you want to overwrite it or not.
	If System.IO.File.Exists(oNewFileName) = True Then
		oAnswer = MsgBox("A PDF file with this name already exists." & vbCrLf &
		"Do you want to overwrite it with this new one?",vbYesNo + vbQuestion + vbDefaultButton2, "PDF ALREADY EXISTS")
		If oAnswer = vbNo Then Exit Sub
	'The following If-Then statement defines the Options available, and their Values.
	If oPDFAddin.HasSaveCopyAsOptions(oDDoc, oContext, oOptions) Then
		oOptions.Value("Publish_All_Sheets") = 1 ' 0 = False, 1 = True
		'oOptions.Value("Sheet_Range") = Inventor.PrintRangeEnum.kPrintAllSheets
		'oOptions.Value("Sheet_Range") = Inventor.PrintRangeEnum.kPrintCurrentSheet
		'oOptions.Value("Sheet_Range") = Inventor.PrintRangeEnum.kPrintSheetRange
		'oOptions.Value("Custom_Begin_Sheet") = 1
		'oOptions.Value("Custom_End_Sheet") = 4
		oOptions.Value("Launch_Viewer") = 0 ' 0 = False, 1 = True
		oOptions.Value("All_Color_AS_Black") = 0 ' 0 = False, 1 = True
		oOptions.Value("Vector_Resolution") = 720 '150, 200, 400, 600, 720, 1200, 2400, 4800 ' DPI
		oOptions.Value("Remove_Line_Weights") = 0 ' 0 = False, 1 = True
	'Publish PDF
	oPDFAddin.SaveCopyAs(oDDoc, oContext, oOptions, oDataMedium)
End Sub
Sub ExportToSTEP(oDoc As Document, oNewFileName As String)
	'get file name without path, but with file extension (for use with iProperties calls)
	oDocName = System.IO.Path.GetFileName(oDoc.FullFileName)
	Dim oSTEP As TranslatorAddIn
	For Each oAddIn As ApplicationAddIn In ThisApplication.ApplicationAddIns
		If oAddIn.DisplayName = "Translator: STEP" Then
			oSTEP = oAddIn
	Next
	If IsNothing(oSTEP) Then
		MsgBox("STEP Translator Add-in not found.  Exiting.", vbCritical, "iLogic")
		Exit Sub
	'create needed variables for translator
	'Check to see if the STEP file already exists, if it does, ask if you want to overwrite it or not.
	If System.IO.File.Exists(oNewFileName) Then
		oAns = MsgBox("A STEP file with this name already exists." & vbCrLf &
		"Do you want to overwrite it with this new one?",vbYesNo + vbQuestion + vbDefaultButton2, "STEP FILE EXISTS")
	If oSTEP.HasSaveCopyAsOptions(oDoc, oContext, oOptions) Then
		' Set application protocol.
		 ' 2 = AP 203 - Configuration Controlled Design
		 ' 3 = AP 214 - Automotive Design
		 oOptions.Value("ApplicationProtocolType") = 3
		 oOptions.Value("IncludeSketches") = True
		 oOptions.Value("export_fit_tolerance") = .000393701  'minimum
		 oOptions.Value("Author") = ThisApplication.GeneralOptions.UserName
		 oOptions.Value("Authorization") = ""
		 oOptions.Value("Description") = iProperties.Value(oDocName, "Project", "Description")
		 oOptions.Value("Organization") = iProperties.Value(oDocName, "Summary", "Company")
		Try
			 oSTEP.SaveCopyAs(oDoc, oContext, oOptions, oDataMedium)
		Catch
			MsgBox("Your attempt to export this document as a STEP file FAILED!", vbOKOnly + vbExclamation, "Export to STEP Error")
		End Try
End Sub
If this solved your problem, or answered your question, please click ACCEPT SOLUTION.
Or, if this helped you, please click (LIKE or KUDOS) 👍.
If you want and have time, I would appreciate your Vote(s) for My IDEAS 💡 or you can Explore My CONTRIBUTIONS
Wesley Crihfield
Message 11 of 16
Sprocket1077
Hi WCrihfield.
Thank you very much for the work you did.
But as I tried it, it does not work.
I jammed at start.
Here is my error message.
FYI, my revision number will always be a number.
It start with 00 then 01, 02, 03, etc.
Sorry for the dialog box, the message is in french.
Awaiting your reply.
Thank you.
Message 12 of 16
WCrihfield
OK. It looks to me like at some point it is causing this error because it won't convert a String into an Integer. This is obviously where I'm trying to retrieve the value of that Revision Number iProperty as an Integer.  I just double checked my documentation about that specific iProperty, and it is supposed to return a String.  So, I likely just need to change how I'm defining my variables in that area of the code (2 places).  I updated that part of the code (in those 2 places), and I'm hoping this fixes the problem.  Now I'm pre-defining that oRevNum variable as a String, instead of an Integer, which should eliminate that error message.  Then, in order to still use that little formatting trick, I'm using a simple data type converter to convert the String into an Integer, then back to a String, with the formatting we want, and setting that as the value of the oRev variable (which is also a String).  I believe this ToString("00") needs to be following an Integer type data of a 2 digit value or less.  I also added a couple lines in there to ensure the values of these two variables gets reset to an empty string each time around, just to be extra safe.
Sub Main
		Exit Sub
	'get Revision Number Value (Won't work if using Letters!)
	Dim oRevNum As String = oADoc.PropertySets(1).Item("Revision Number").Value
	If String.IsNullOrEmpty(oRevNum) Then
		oRevNum = "0" 'a zero in quotes
	Dim oRev As String = "-R" & CInt(oRevNum).ToString("00")
		oRevNum = String.Empty 'ensuring it is reset to an empty string
		oRevNum = oRefDoc.PropertySets(1).Item("Revision Number").Value
		oRev = String.Empty 'ensuring it is reset to an empty string
		oRev = "-R" & CInt(oRevNum).ToString("00")
	Next
End Sub
		oDDoc = oDoc
	Else
		Else
			Exit Sub
			oPDFAddin = oAddin
	Next
	'Publish PDF
End Sub
			oSTEP = oAddIn
	Next
		Exit Sub
		Try
		Catch
		End Try
End Sub
Wesley Crihfield
Message 13 of 16
Sprocket1077
Hi again WCrihfield.
You are great but I'm stuck again.
It seems that it does not find the starting assembly witch I'm in.
Can we try something else?
Message 14 of 16
A.Acheson
Can you screen shot the more info section of the error message.
To narrow down the error switch of each sub routine like so in both the main assembly and the for loop of the reference documents. Then switch on the main assembly first to ensure this section is working and then the reference documents.
'ExportToPDF(oADoc, oNewPDFName)
	'ExportToSTEP(oADoc, oNewSTEPName)
Regards
Alan
Message 15 of 16
Sprocket1077
Hi A.Acheson.
Thank you very much to try to help me with this.
Here is the error message.
I looked for the result and I have to say that even if it returns an error message about the assembly file, the PDF file of the assembly have been made. (Then it stops)
Also I don't need the step file of the assembly.
The final result should be an assembly pdf file and all parts pdf files and step files with revision number as suffix.
Here is an image of what should be the result.
Please notice that I understand what you try to do in the macro, but I'm not good enough with VB to execute it as you told me.
Can we try something again?
Thanks.
Message 16 of 16
WCrihfield
That more detailed error message indicates that it is still encountering an error while attempting to access the iProperties of a component or document.  However, the way that error message is laid out, looks like it was trying to use the iLogic snippet for iProperties (iProperties.Value(componentOrDocName As Object, setName As String, propertyName As String)), but I'm not using that snippet of code anywhere in the code I posted.  I'm using the traditional API route to access the iProperties (Document.PropertySets.PropertySet.Property.Value).  Since the only place I'm trying to access iProperties is in the Sub Main portion of the code, I don't suspect any problems with the other two Sub routines at this time.  However, if the file name given to those sub routines has not been assembled property before it is given to them, this might cause a problem.  I'm now thinking that we may need to include a couple of Try...Catch...End Try blocks of code in there around the two lines of code where we are accessing the iProperty, and include a feedback message about when it encounters an error/failure, so we can better pinpoint the problem.
Wesley Crihfield
