- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi All,
I have a bolt which has been assembled 3 times in an assy. Then this bolt is patterned around the axis of the part using circular pattern command. Let's call this pattern A. So now, Pattern A has 2 instances Element 1 and Element 2 and each instance have 3 bolts in it.
Pattern A is again patterned "n" no of times around another axis using circular pattern command. So now, pattern A is sitting inside another pattern. Let's call it Pattern B.
So Pattern B is the top level pattern which contains pattern A as its instances "n" no of times. Pattern A then contains 2 instance as given above. I also have same bolt existing in the model tree outisde pattern B.
I need iLogic code to do component replace on the bolt inside pattern B. The code should replace all instaces of the bolts but only inside the pattern B. Any bolt existing outside pattern B should remain unchanged.
Can anyone help with this please? I have searched internet to find something similar but no luck.
Thanks in advance.
