Passing variables between ilogic subs
schleede.dave
schleede.dave
I'm not very good with iLogic so please bear with me.  I am trying to figure out how to pass information between two separate private subs contained within the same Rule.  I think I understand how to get info from the first sub to the second but I don't know how to pass info back.  Can anyone explain this to me?
MechMachineMan
Subs, as you will find in any programming that use them, are there because they are NOT supposed to return a value. It's not their intent. They are supposed to be there to perform a task based upon the given inputs.
If you want to return a value, you need to use a Function. Which has all the same functionality of a sub, but can return a value.
HOWEVER, you can declare variables as shared/global so that a Sub can act on them... however, this can make it hard to follow the data around when it comes to debugging.
Example:
Sub Main
     Dim x As Integer = 5
     Dim y As Integer = 2
     Call MathSub(x,y)
     FunctionResult = MathFunction(x,y)
     MsgBox("This is in main sub. The result of the function call is: " & FunctionResult)
End Sub
'note the sub does not have a type
Sub MathSub(var1 as Integer, var2 as Integer)
         Dim resultvar As Integer
         resultvar = var1 + var2
         MsgBox("I am in the sub MathSub. The result I give is: " & resultvar)
End Sub
'note the function has to have a type
Function MathFunction(var1 as Integer, var2 as Integer) As Integer
       Dim result As Integer
       result =  var1-var2
       Return result
End Function
Example using global variables:
See: for more info on access modifiers:
https://msdn.microsoft.com/en-us/library/76453kax.aspx
'Need to put all of the rule inside of a class in order to be able to use the shared variable.
Class TestShared
	'This shared access modifier keyword makes the information accessible to all subs/functions/properties in this class
	Shared oResult As Integer
		Sub Main
			oResult = 0
			MsgBox("Before sub call result: " & vbLf & oResult)
			PerformMath(x, y)
			MsgBox("After sub call result: " & vbLf & oResult)
		End Sub
		Sub PerformMath(var1 as Integer, var2 as Integer)
				oResult = var1 + var2
		End Sub
End Class
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
schleede.dave
Thanks for the help. I'm going to try applying what you've shown me when I'm back in the office tomorrow.  Hopefully I can make it work!
schleede.dave
Didn't get around to working on the iLogic code until today.  I was able to get things working using your example as a guide.  Thank you for the help!
MechMachineMan
No problem! Good luck in your future code escapades!
Justin K
