Passing Information to Command Manager Events
MechMachineMan
Advisor Advisor
Message 1 of 1
MechMachineMan
Is there a way to specify the % visible and uncheck the compact set when using the command:
SyntaxEditor Code Snippet
Dim oControlDef1 As ControlDefinition
 oControlDef1 = oCommandMgr.ControlDefinitions.Item("AssemblyVisibilityCheckerCmdAllInCamera")
oControlDef1.Execute
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Replies (0)
