pass value between external ilogic rules
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hey Guys,
I'm hacking my way though a rule and have wasted a day fiddle farting around with it.
Maybe someone can help?
What I want to do is call an External rule and use the value of a declared variable from the parent rule (that is, that calls it the external rule).
Here's basically what I'm trying to do:
1. create all flatpattern files in individual idw files then run some other external commands on them (good to go on that stuff...only thing is all the idw files don't get saved after they're made)
2. then save each idw file and close it by calling an external file that uses the filename that the parent iLogic rule created. the idw file had not yet been saved before the rule is called that saves it.
I just can't figure out how to do any of that from within the parent rule b/c it keeps saving and closing the iam file instead of the idw files.
Actually, I'm resorting to saving the idw file b/c I can't figure out how to make a dxf file from the idw file without saving it, and then closing the idw file without saving it after creating the dxf file. Plus, I want to save the dxf file by the name created in the parent iLogic file that gets its iProperties from each part file. This is a clusterf**k of coding that I just can't figure out. Incidentally, I've read at least 4 hours of stuff online to try to figure this out, but just can't find what I need to know to do it successfully. Plus I tried adapting at least 8 ilogic rules to do it, but can't figure it out. I even tried starting w/the embedded iLogic sippet "export dxf from idw" but it got me all knotted up, even though I KNOW I got the ini file and template names correct.
Any guidance is appreciated.
Win 7 Pro 64 bit + IV 2010 Suite
ASUS X79 Deluxe
Intel i7 3820 4.4 O/C
64 Gig ADATA RAM
Nvidia Quadro M5000 8 Gig
3d Connexion Space Navigator
