Part List Ballooned Components Only. Missing attached balloons.
davis.j
davis.j
This Ilogic rule I have works great but the parts list is not including all of the attached balloons. It seems to look at the last attached balloon and not register the others. Can someone here assist me with this? 🙂
Dim oDoc As Document = ThisDoc.Document
oNamer = "BOM PL Balloons"
Dim UNDO As Transaction
UNDO = ThisApplication.TransactionManager.StartTransaction(oDoc, oNamer)
'Your iLogic code goes in here:
If oDoc.DocumentType <> kDrawingDocumentObject Then
	MessageBox.Show("Run in drawings only!", "Error", MessageBoxButtons.OK, MessageBoxIcon.Stop)
	Exit Sub
Dim oSheet As Sheet = oDoc.ActiveSheet
If oSheet Is Nothing Then
	MessageBox.Show("Only valid for dwg files with sheets!", "Error", MessageBoxButtons.OK, MessageBoxIcon.Stop)
	Exit Sub
If oSheet.PartsLists.Count = 0 Then
	MessageBox.Show("Only valid for sheets with a BOM.", "Error", MessageBoxButtons.OK, MessageBoxIcon.Stop)
	Exit Sub
Dim oPL As PartsList = oSheet.PartsLists(1)
If oPL.PartsListRows.Count < 1 Then
	MessageBox.Show("Only valid For partslists With actual rows", "Error", MessageBoxButtons.OK, MessageBoxIcon.Stop)
	Exit Sub
If oSheet.Balloons.Count < 1 Then
	MessageBox.Show("Rule only valid For sheets With balloons!", "Error", MessageBoxButtons.OK, MessageBoxIcon.Stop)
	Exit Sub
On Error Resume Next
For Each oRow In oPL.PartsListRows
	oRow.Visible = False
Next
If Err.Number <> 0 Then
	MessageBox.Show("Issue setting row visibility Or accessing rows...", "Error", MessageBoxButtons.OK, MessageBoxIcon.Stop)
Err.Clear
Dim oBalloon As Balloon
Dim oBVS As BalloonValueSet
Dim oIN As String
For Each oBalloon In oSheet.Balloons
	For Each oBVS In oBalloon.BalloonValueSets
		oIN = oBVS.ItemNumber
			MessageBox.Show("Issue grabbing Balloon item number...", "Error", MessageBoxButtons.OK, MessageBoxIcon.Stop)
	Next
Err.Clear
	If oRow.Item(1).Value = oIN
		oRow.Visible = True
	Next
		MessageBox.Show("Issue iterating PL/setting visibility back On", "Error", MessageBoxButtons.OK, MessageBoxIcon.Stop)
Err.Clear
Next
	On Error GoTo 0
UNDO.End
Michael.Navara
I don't know how your BalloonValueSets looks, but you store ItemNumber only from the last of them.
Next
The second thing is your use of Transactions
Transaction MUST BE CLOSED in any way. When you end your rule by Exit Sub,  your UNDO transaction MUST be closed with UNDO.End() or UNDO.Abort(). Otherwise, Invnetor crashes
