Part won't update after rule runs, after ipart member change
SharkDesign
Mentor Mentor
Message 1 of 25
SharkDesign
I have an ilogic rule that spaces the holes out on a linear rail.
Everything works perfectly until I convert it to iPart. I need to do this for content centre.
When I change between factory members, the rule runs (I put a message box in to prove it) But the part doesn't update afterwards, despite using
iLogicVb.UpdateWhenDone = True
Any ideas?
This is the abridged version
Parameter.UpdateAfterChange = True
If Size = "HGR15" Then
HoleCB = "7.5"
etc etc.......
BlindThreadDepth = 8
Else If Size = "HGR20" Then
etc etc................
ThisApplication.ActiveView.Fit
Inventor 2018
  Inventor Certified Professional
Replies (24)
Message 21 of 25
HermJan.Otterman
the rule now runs, when you change to an other size,
To update your part:
On the last line of the rule, add:
that should update your part
If this answers your question then please select "Accept as Solution"
Kudo's are also appreciated Smiley Wink
Succes on your project, and have a nice day
Herm Jan
Message 22 of 25
clutsa
Try throwing this at the bottom.
Dim app As Inventor.Application = ThisApplication
Dim LocalUpdate As ControlDefinition = app.CommandManager.ControlDefinitions("AppLocalUpdateCmd")
LocalUpdate.Execute
If I've helped you, please help me by supporting this idea.
Mass Override for Each Model State
Custom Glyph Icon for iMates
Message 23 of 25
SharkDesign
Bloody ell that's so complicated. Is there a reason the normal "iLogicVb.UpdateWhenDone = True" doesn't work?
Message 24 of 25
clutsa
I wish I could give you a definitive answer as to why document.update and updatewhendone = true don't always work but, from my best understanding when the document updates it causes some other parameters to update and that doesn't trigger another update (probably to stop some potential infinite loop) so you're left with a dirty document even after update... I may be full of bologna however.
here's the same code as one line if that makes you feel better (it won't.)
ThisApplication.CommandManager.ControlDefinitions("AppLocalUpdateCmd").Execute
Message 25 of 25
HermJan.Otterman
so did you follow my steps? or just added this line?
if I only add your line, then the rule still is not triggered and don't run. , or does it run with you.?
once the rule is triggered, the "Update when done" updates the part with me....!?
Herm Jan
