Multi text in drawing
jostroopers
jostroopers
I created a text parameter in a part.
This parameter contains a multi value with two values.
In my Inventor .dwg I have placed a text that is linked to the multi text parameter.
In my iLogic rule I want to switch between the multi values at a certain length.
However, it does not work, perhaps I am using the wrong snippet.
Who can help me.
Mvg Jos
Youre drawings are as good as the symbols that compleet them.....
Sergio.D.Suárez
Hi, try placing each value in quotes
Parameter ("FDF022_B.ipt.PlaatsGaten") = "Gaten vanuit het midden profiel"
I hope this helps. regards
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
