Part won't update after rule runs, after ipart member change
SharkDesign
Mentor Mentor
Message 1 of 25
SharkDesign
I have an ilogic rule that spaces the holes out on a linear rail.
Everything works perfectly until I convert it to iPart. I need to do this for content centre.
When I change between factory members, the rule runs (I put a message box in to prove it) But the part doesn't update afterwards, despite using
iLogicVb.UpdateWhenDone = True
Any ideas?
This is the abridged version
Parameter.UpdateAfterChange = True
If Size = "HGR15" Then
HoleCB = "7.5"
etc etc.......
BlindThreadDepth = 8
Else If Size = "HGR20" Then
etc etc................
ThisApplication.ActiveView.Fit
Inventor 2018
  Inventor Certified Professional
Replies (24)
Message 2 of 25
JamieVJohnson2
try the update (and/or Update2(accept errors = true/false)) command on the PartDocument class:
Dim partDoc As PartDocument = ThisDoc.Document
partDoc.Update
Jamie Johnson : Owner / Sisu Lissom, LLC https://sisulissom.com/
Message 3 of 25
SharkDesign
Sorry I don't know how to do this, is there a link to the method?
James
Message 4 of 25
chandra.shekar.g
Autodesk Support
Autodesk Support
@SharkDesign,
@JamieVJohnson2 - saying that modify the code like below.
HoleCB = "7.5"
etc etc.......
partDoc.Update iLogicVb.UpdateWhenDone = True ThisApplication.ActiveView.Fit
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
Message 5 of 25
SharkDesign
I thought that was what you meant, I did that and it didn't work.
Message 6 of 25
chandra.shekar.g
Autodesk Support
Autodesk Support
@SharkDesign,
Can you please provide non confidential data to test the behavior?
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 7 of 25
SharkDesign
Yes, can I email it to you please?
Message 8 of 25
chandra.shekar.g
Autodesk Support
Autodesk Support
@SharkDesign,
The highlighted red line below iLogic code is not allowing to change the "Size" parameter. It is reading the value from custom iProperties (Size).
'Parameter.UpdateAfterChange = True
'Size = iProperties.Value("Custom", "Series")
'If Feature.IsActive("Thru hole") = True Then
'	HoleType = "Thru"
'Else If Feature.IsActive("Blind Hole") = True Then
'	HoleType = "Blind"
'End if
'Extrusion selector
'Feature.IsActive("HGR15") = True
'Feature.IsActive("HGR20") = False
'Feature.IsActive("HGR25") = False
'Feature.IsActive("HGR30") = False
'Feature.IsActive("HGR35") = False
'Feature.IsActive("HGR45") = False
'Feature.IsActive("HGR55") = False
'Feature.IsActive("HGR65") = False
HoleCB = "7.5"
CBdepth = "5.3"
HoleW = "4.5"
Pitch = "60"
Evalue = "6"
HoleHi = "15"
BlindTheadDes = "M5x0.8"
'Feature.IsActive("HGR15") = False
'Feature.IsActive("HGR20") = True
HoleCB = "9.5"
CBdepth = "5.3"
HoleW = "4.5"
Pitch = "60"
Evalue = "7"
HoleHi = "17.5"
BlindTheadDes = "M6x1"
BlindThreadDepth = 10
Else If Size = "HGR25" Then
'Feature.IsActive("HGR25") = True
HoleCB = "11"
CBdepth = "9"
HoleW = "7"
Pitch = "60"
Evalue = "8"
HoleHi = "22"
BlindThreadDepth = 12
Else If Size = "HGR30" Then
'Feature.IsActive("HGR30") = True
HoleCB = "14"
CBdepth = "12"
HoleW = "9"
Pitch = "80"
Evalue = "9"
HoleHi = "26"
BlindTheadDes = "M8x1.25"
BlindThreadDepth = 15
Else If Size = "HGR35" Then
'Feature.IsActive("HGR35") = True
HoleCB = "14"
CBdepth = "12"
HoleW = "9"
Pitch = "80"
Evalue = "9"
HoleHi = "29"
BlindThreadDepth = 17
Else If Size = "HGR45" Then
'Feature.IsActive("HGR45") = True
HoleCB = "20"
CBdepth = "17"
HoleW = "14"
Pitch = "105"
Evalue = "12"
HoleHi = "38.1"
BlindTheadDes = "M12x1.75"
BlindThreadDepth = 24
Else If Size = "HGR55" Then
'Feature.IsActive("HGR55") = True
HoleCB = "23"
CBdepth = "20"
HoleW = "16"
Pitch = "120"
Evalue = "14"
HoleHi = "44"
BlindTheadDes = "M14x2"
Else If Size = "HGR65" Then
'Feature.IsActive("HGR65") = True
HoleCB = "26"
CBdepth = "22"
HoleW = "18"
Pitch = "150"
Evalue = "15"
HoleHi = "53"
BlindTheadDes = "M20x2.5"
BlindThreadDepth = 30
'Hole placement
NumHoles = Ceil(L/Pitch)
EndHole = (L - ((NumHoles - 1) * Pitch)) / 2
FirstPitch = (L/2)-EndHole
If EndHole < Evalue Then
OldNumHoles = NumHoles
NumHoles = OldNumHoles - 1
'Hole Type
If HoleType = "Thru" Then
Feature.IsActive("Blind Hole") = False
Else If HoleType = "Blind" Then
Feature.IsActive("Thru hole") = False
Feature.ThreadDesignation("Blind Hole") = BlindTheadDes
'Update Part Number
HT="R"
HT="T"
HG=Size
'iProperties.Value("Project", "Part Number")= HG & HT & L & C
'iProperties.Value("Project", "Description")= HG & " Linear Rail"
'PartName=iProperties.Value("Project", "Part Number")
partDoc.Update
'targetFolder="C:\Hiwin Rail\"
'If Not System.IO.Directory.Exists(targetFolder) Then
'    System.IO.Directory.CreateDirectory(targetFolder)
'End If
'ThisDoc.Document.SaveAs(targetFolder & PartName & ".ipt" , True)
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 9 of 25
SharkDesign
You can't have a text parameter value in an ipart table, so the idea was that assigning the 'series' from the ipart table, the parameter 'size' would then update and trigger the values in the rule.
So when it goes to content center you will have the options.
Series
Length
Hole type
User selects Series which is an ipart table value
This writes the value to custom iproperties
iLogic reads this custom iproperty to the parameters 'size' and updates the rest from there.
Is there anther way to do this?
Message 10 of 25
chandra.shekar.g
Autodesk Support
Autodesk Support
@SharkDesign,
Hoping that below changes may be helpful.
'	HoleType = "Thru"
'End if
'Extrusion selector
Dim sizeValue As String
sizeValue = iProperties.Value("Custom", "Series")
If sizeValue = "HGR15" Then
	Size = "HGR15"
HoleCB = "7.5"
CBdepth = "5.3"
HoleW = "4.5"
Pitch = "60"
Evalue = "6"
HoleHi = "15"
Else If sizeValue = "HGR20" Then
	Size = "HGR20"
HoleCB = "9.5"
CBdepth = "5.3"
HoleW = "4.5"
Pitch = "60"
Evalue = "7"
HoleHi = "17.5"
Else If sizeValue = "HGR25" Then
	Size = "HGR25"
HoleCB = "11"
CBdepth = "9"
HoleW = "7"
Pitch = "60"
Evalue = "8"
HoleHi = "22"
Else If sizeValue = "HGR30" Then
	Size = "HGR30"
HoleCB = "14"
CBdepth = "12"
HoleW = "9"
Pitch = "80"
Evalue = "9"
HoleHi = "26"
Else If sizeValue = "HGR35" Then
	Size = "HGR35"
HoleCB = "14"
CBdepth = "12"
HoleW = "9"
Pitch = "80"
Evalue = "9"
HoleHi = "29"
Else If sizeValue = "HGR45" Then
	Size = "HGR45"
HoleCB = "20"
CBdepth = "17"
HoleW = "14"
Pitch = "105"
Evalue = "12"
HoleHi = "38.1"
Else If sizeValue = "HGR55" Then
	Size = "HGR55"
HoleCB = "23"
CBdepth = "20"
HoleW = "16"
Pitch = "120"
Evalue = "14"
HoleHi = "44"
Else If sizeValue = "HGR65" Then
	Size = "HGR65"
HoleCB = "26"
CBdepth = "22"
HoleW = "18"
Pitch = "150"
Evalue = "15"
HoleHi = "53"
'Hole placement
'Hole Type
'Update Part Number
HT="R"
HT="T"
HG=Size
partDoc.Update
'End If
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 11 of 25
SharkDesign
The extrusion suppression changes but I now have to run the 'hole placement' rule manually twice to get the holes to update.
Message 12 of 25
chandra.shekar.g
Autodesk Support
Autodesk Support
@SharkDesign,
Enable or add below line at start of iLogic code and check the same.
 Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 13 of 25
SharkDesign
Nope, I still have to update manually twice.
Message 14 of 25
HermJan.Otterman
can you share your file here?
If this answers your question then please select "Accept as Solution"
Kudo's are also appreciated Smiley Wink
Succes on your project, and have a nice day
Herm Jan
Message 15 of 25
SharkDesign
Here it is.
When you change ipart member, it doesn't update without manually running the ilogic code.
Message 16 of 25
clutsa
What version of Inv are you running?
If I've helped you, please help me by supporting this idea.
Mass Override for Each Model State
Custom Glyph Icon for iMates
Message 17 of 25
SharkDesign
Message 18 of 25
clutsa
try setting an arbitrary variable and see if that triggers it how you think it should. Something like
arbitraryVar = L 'or any of the parameters in your model [but you can't use Parameter("L") or it won't trigger]
Message 19 of 25
HermJan.Otterman
Hello James,
your rule is not triggered
the "Parameter.UpdateAfterChange" apperently does noting, maybe no parameters is changed....
I saw in you parameters the Size parameter but it did not change either.
So I created a new Size_Number parameter, and added it to the iPart table as you can see in me Screencast.
then when you change the iPart member, that parameter will change.
to start the rule, enter the line "trigger = Size_Number" that will trigger the rule.
((trigger may be anything it is just a variable that changes))
look at my screencast: https://autode.sk/2yoFq4c
Herm Jan
Message 20 of 25
SharkDesign
Thank you, that still doesn't work though. If you look in your screencast, the update symbol is there after changing members. It won't update itself.
