part weight settings
Hi, all!  I tried searching for this issue, no luck... for a lot of the parts in our Library we have a simple model which fills our needs, and we "overwrite" the weight of the model file so it is correct.  We have a macro which we use to fill in iProperties, and I would like to include this option, but I can't find the Design Tracking Property code to use.  Is it possible to overwrite the weight of a model using VBA?  We are using Inventor R2011, SP2 (yes, we're a bit behind the times... hoping to be able to upgrade sooooonnnnn Smiley Happy)
rossano_praderi
Hi Joe,
I'm not using Inventor 2011 and I can't test this code on that release.
The follow VBA code give the complete list of propertysets.
Sub test()
    Dim oDoc As Document
    Set oDoc = ThisApplication.ActiveDocument
    For i = 1 To oDoc.PropertySets.Count
        Debug.Print oDoc.PropertySets.Item(i).Name
        For e = 1 To oDoc.PropertySets.Item(i).Count
            Debug.Print "-> " & oDoc.PropertySets.Item(i).Item(e).Name
        Next
    Next
End Sub
' changing the Mass can be like this
' oDoc.PropertySets.Item("Design Tracking Properties").Item("Mass") = YourMass
Bregs
Rossano Praderi
If my post answers your question, please click the "Accept as Solution"
button. This helps everyone find answers more quickly!
Thanx a bunch, the code runs in 2011, so the functionality is there.  It doesn't update the model file, is there a need to "apply" or "update" the change?  Thanx again
dano0310
For a list that can be printed out check page 13 of "Exploring iProperties and Parameters".  It was from 2008 but still relevant. Click here
The code below:
MsgBox ("The mass of this item is " & ThisApplication.ActiveDocument.PropertySets(3).ItemByPropId(58).Value)
Returns the mass from iProps.  It can also be written
Property set 1 is the Inventor Summary information
Property set 2 is the Inventor Document Summary information
Property set 3 is the Design tracking properties
rossano_praderi
Yes, you should use "oDoc.update".
Thanx, everyone for their help!  Accessing the Design Tracking Property gave me the mass of the model, but changing it didn't change the mass (???).  I used this code and it did the job.
Dim oAssyDoc As AssemblyDocument
Dim oPartDoc As PartDocument
Dim oMass As Double
    'Set oAssyDoc = ThisApplication.ActiveDocument
    Set oPartDoc = ThisApplication.ActiveDocument
    Dim oMassProps As MassProperties
    'Set oMassProps = oAssyDoc.ComponentDefinition.MassProperties
    Set oMassProps = oPartDoc.ComponentDefinition.MassProperties
oMass = (whatever the new value is, I'm getting it from a User Form)
oMassProps.Mass = oMass
Debug.Print "Mass: " & oMassProps.Mass
This approach works in R2011, don't know about any newer release.  Sorry, I don't know how to post the code to its own window.
