Cant find sample code
rfink
rfink
Where can I get the below indicated sample code. It is in the Inventor Help Utility, but I cant find it in the suggested directory.
A sample VBA macro to access iLogic can be found at the following location:
  • Windows 7 and Windows 8
    Users\Public\Documents\Autodesk\Inventor [version]\Samples\ iLogic Samples\API\iLogicAutoTest.ivb
In the sample code, the GetiLogicAddin function demonstrates how to access the iLogic Automation object in VBA or VB.
Owner2229
Here you go:
Public Sub RunMyRule()
   ' Run an external rule
RuniLogicExt "C:\MyPath\MyRule.iLogicVb"
' Run an internal rule
RuniLogicInt "MyRule"
End Sub Private Sub RuniLogicInt(ByVal RuleName As String) Dim iLogicAuto As Object Dim oDoc As Document Set oDoc = ThisApplication.ActiveDocument If oDoc Is Nothing Then MsgBox "Missing Inventor Document" Exit Sub End If Set iLogicAuto = GetiLogicAddin(ThisApplication) If (iLogicAuto Is Nothing) Then Exit Sub iLogicAuto.RunRule oDoc, RuleName End Sub
Private Sub RuniLogicExt(ByVal RuleName As String) Dim iLogicAuto As Object Dim oDoc As Document Set oDoc = ThisApplication.ActiveDocument If oDoc Is Nothing Then MsgBox "Missing Inventor Document" Exit Sub End If Set iLogicAuto = GetiLogicAddin(ThisApplication) If (iLogicAuto Is Nothing) Then Exit Sub iLogicAuto.RunExternalRule oDoc, RuleName End Sub
Function GetiLogicAddin(oApplication As Inventor.Application) As Object Set addIns = oApplication.ApplicationAddIns Dim addIn As ApplicationAddIn On Error GoTo NotFound Set addIn = oApplication.ApplicationAddIns.ItemById("{3bdd8d79-2179-4b11-8a5a-257b1c0263ac}") If (addIn Is Nothing) Then Exit Function addIn.Activate Set GetiLogicAddin = addIn.Automation Exit Function NotFound: End Function
Consider using "Accept as Solution" / "Kudos" if you find this helpful.
Mike
"Always code as if the guy who ends up maintaining your code will be a violent psychopath who knows where you live." - John F. Woods
rfink
Mike,
Thanks, this is what I was looking for.
Do you know if there is any reference material (objects, methods, properties, ect) regarding the iLogic Add In.
Ross
Owner2229
You can find a lot of resource materials in:
Inventor > Question mark in top right corner > Help > Help for API
Lots of geat blogs are posted here by @ekinsb and @adam.nagy:
Modthemachine
You can also just ask here on forum for whatever you want to know.
Or tell me what exactly you want to know and I'll try to help you.
Mike
