Parameters
Parameters
GosponZ
Message 1 of 14
Parameters
GosponZ
I do have lot old files i need to add True/ False Parameter  ABC . Can somebody help please. Thanks
Replies (13)
Message 2 of 14
bradeneuropeArthur
You van do that with Windows Explorer selves!
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 14
GosponZ
iLogic code would be nice. Do not understand with Windows explorer
Message 4 of 14
bradeneuropeArthur
  1. Select files
  2.
  3. bradeneuropeArthur_0-1628252199335.pngbradeneuropeArthur_1-1628252306255.png
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 5 of 14
GosponZ
Thanks for you replay but this is what i need
Message 6 of 14
bradeneuropeArthur
Correct I have read wrong!
I will help you further...
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 7 of 14
bradeneuropeArthur
Dim d As Inventor.FileDialog
 Call ThisApplication.CreateFileDialog(d)
d.MultiSelectEnabled = True
d.Filter = "Parts|*.ipt"
d.ShowOpen
d.CancelError = False
If Not d.FileName = "" Then
	Dim a() As String = Split(d.FileName, "|")
i=0
For i = 0 To UBound(a)
Dim odoc As Inventor.PartDocument = ThisApplication.Documents.Open(a(i))
odoc.ComponentDefinition.Parameters.UserParameters.AddByValue("ABC", True, "BOOLEAN")
odoc.Save
	odoc.Close
Next
EDIT
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 8 of 14
GosponZ
Great it is working. Before close and accept let me ask you this. Can it be done if part is already open, or can it be done to run code from assembly in all parts?
Appreciate once again for you time and help
Message 9 of 14
bradeneuropeArthur
sure.
You mean for the active part also put parameter ABC = true/false
and loop through assembly parts and put parameter ABC = true/false
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 10 of 14
GosponZ
Yes
Message 11 of 14
bradeneuropeArthur
Sub main
Dim a As AssemblyDocument = ThisApplication.ActiveDocument
loopi(a)
End Sub
 Sub Loopi(a As AssemblyDocument)
	Dim c As ComponentOccurrence
For Each c In a.ComponentDefinition.Occurrences
	Dim d As Document = c.Definition.Document
	If d.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject
		loopi(d)
	Else If d.DocumentType = DocumentTypeEnum.kPartDocumentObject
		Dim p As PartDocument = Nothing
	p = d
	p.ComponentDefinition.Parameters.UserParameters.AddByValue("ABCD",True,"BOOLEAN")
	Next
End Sub
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 12 of 14
GosponZ
Thank you so much, lot time will save me.
Message 13 of 14
bradeneuropeArthur
Good to hear!
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 14 of 14
cadman777
@bradeneuropeArthur,
Thanks for this rule.
It works a charm!
Thing is, I need a few more options on it.
Would you please show me how?
First I need to replace the value with the name of a parameter (G_L).
Then I need to Export the parameter, and then format the units of the parameter to decimal 3 places, no zeros and no unit string. If you can point me in the right direction I would be grateful. I keep getting an error about the 'document class' when I try to cut-and-paste other code I find in this forum into this rule. Here is what I did so far:
'Create user parameter in part file after checking for existence and then adding a value to it and formatting it and exporting it
Sub Main
Loopi(a)
End Sub
		Loopi(d)
	p = d
	p.ComponentDefinition.Parameters.UserParameters.AddByValue("G_LD", G_L, UnitsTypeEnum.kInchLengthUnits)
	Next
End Sub
I believe I have to 'expose' the parameter so it can be changed, but don't know how to do it.
Here is a link showing some code to do that, but I don't know how to integrate it into your rule.
Here is the code from that link:
param =Parameter.Param("G_L")
param.ExposedAsProperty = True
param.CustomPropertyFormat.Precision = kThreeDecimalPlacesPrecision
param.CustomPropertyFormat.ShowTrailingZeros = False
param.CustomPropertyFormat.ShowLeadingZeros = False
param.CustomPropertyFormat.ShowUnitsString = False
param.CustomPropertyFormat.Units = "in"
Also, I do not understand what this is doing:
		Loopi(d)
	p = d
Thanx...Chris
... Chris
Win 7 Pro 64 bit + IV 2010 Suite
ASUS X79 Deluxe
Intel i7 3820 4.4 O/C
64 Gig ADATA RAM
Nvidia Quadro M5000 8 Gig
3d Connexion Space Navigator
