Overwrite Line Type of DrawingCurveSegment
C_Haines_ENG
C_Haines_ENG
I cant find how to overwrite the linetype of a line to a custom linetype I have created. I tried to follow the hints but it doesnt seem to work.
oCurve.GetCustomLineType("HIDDEN_V2","Hidden_V2 ____ ____ ____ ____ ____ ____ ____")
That is the code im using, I have looked far and wide on the forms and noboby ever seems to have done this.
bradeneuropeArthur
Does this help?
Public Sub Main
	Try
		Dim a As Inventor.DrawingDocument = ThisDrawing.Document
	Dim b As Inventor.DrawingCurveSegment
Do While True
	Dim f As Inventor.SelectionFilterEnum = Inventor.SelectionFilterEnum.kDrawingCurveSegmentFilter
	b = ThisApplication.CommandManager.Pick(f, "Pick a Drawing View curve")
	Dim l As Inventor.DrawingStylesManager = a.StylesManager' ThisApplication.StylesManager
For Each ls As Inventor.Layer In l.Layers
	'MsgBox (ls.Name)
	Next
	'Dim la As Inventor.Layer = l.Layers.Item("1:02")
	Dim la As Inventor.Layer = l.Layers.Item("02")
	b.Layer = la
	If b Is Nothing Then
		Exit Do
	Loop
		Catch
			End Try
	End Sub
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
WCrihfield
Actually this time you may need to go up a step.  The DrawingCurveSegment has the Layer property, but the DrawingCurve has the LineType & LineWeight property that you can set.
Wesley Crihfield
(Not an Autodesk Employee)
WCrihfield
Also, just in case you did not already know, the DrawingCurve.GetCustomLineType method requires you to create those two 'input' variables ahead of time, with no values set to them yet, then that method will fill in the values for you to those variables.  Then the DrawingCurve.SetCustomLineType() method requires you to input the full file name of the line types file to reference, then the name of the line type, then a Boolean indicating whether to replace an existing line type.
Wesley Crihfield
C_Haines_ENG
SetCustomLineType did the trick
oCurve.SetCustomLineType("FILE PATH","HIDDEN_V2",True)
